R33 GTR motor Question
Guest cop_zilla_69
I have a non turbo R33 gts 95 r33 M spec.
A .Can i put an r33 GTR motor in it , engine mounts, wiring etc with out to much trouble.
B .I live in brisbane aust how much would it cost to import a secondhand reconditioned GTR motor.
C .I can either do the above with gtr bodykit,mags,badges or would it be a better idea to sell my car buy a decent r33 gts-t and attempt to bring it up to 300kw
Thxs opinion appreciated
https://www.sau.com.au/forums/topic/4913-r33-gtr-motor-question/
Sell the thing and buy one that was fitted with a turbo standard.
Why you might ask well:
the na has weaker
diff
suspension
breaks
ect...ect
the cost of upgrading all of the things to a gts-t level would be much much more than the differance of the two cars, therefore if ya want a turbo, buy a car that was built with one (or Two) from factory.
DAMQIK.
Call me a picky bugger, but there's no such thing as a non turbo "M spec". M spec designates the turbo version of the R33 RWD range.
You've made the right choice, selling & starting with a turbo model.
Sounds to me like 33GTS-4 with big brakes fitted. If it is, then you could also consider getting a GTR front cut and swapping in all the bits. This would be the low cost way, but is a lot of work.
If you sell your car and buy a GTR it is going to save a lot of trouble, but cost more. Depends on how you value your time, and if you have the tools, knowledge, and facilities I suppose.
Hippy,
That’s what I call “taking me literally” :lol: :mad:
CK69,
The range of factory options for the R33 (& other models) is huge! The factory body kit could be selected on the turbo or non-turbo. Pitty they didn’t offer 4WD as an option (except the GT-R). If your R33 has 4WD & isn't a GT-R then it the R33 GTS-4.
i know what you mean! i saw the prices too and i nearly cried... didnt full on cry though... i'm strong :lol:
BTW: anyone know how much for 1JZ and 2JZ engine? are they more or less expensive than a GTR motor? coz in terms of build quality, they are about the same.
Originally posted by Silver-Arrowz
The cheapest I've seen a GTR motor for is $6500.
Add all the bits that you need plus fitting and you'll probably cry.
It is in it's own way a better motor. 2JZ have more and better torque than RB26. Also more reliable cause it's doesn't rev as hard as the RB26.
I assume it would also be expensive.
I reckon the beat bargin motors going around are the RB20's.
The 2JZ-GTE is 3 litres, it has the same 86mm bore as the RB26, but the stroke is 86mm. Sort of like an RB30DET. If the bore is the same in both engines, the valve and port sizes are most probably also the same or very close.
I have no idea what a 2JZ-GTE costs, but I doubt if it would be all that cheap either.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
