  • Replies 151
oh erm. anyone in the army reserves?
Skylinegeoff is full-time army I think?
I expect no holding at Singleton for Sydney anymore! :P last week we did 3 laps of the Army base!!!! haha....
It's a pain when that happens! I've met the guys that work that sector. I work at Newcastle/Williamtown Tower and TCU. The biggest jet we see is prob a B738, plus the military stuff.
The civil ATC system is based upon a computer that can calculate your SY slot time pretty much once you have departed, and that'd be why the controller had to shaft you with the holding :P but hey, if I know the flight number, I'm sure we can sort things out to make you an easy #1...hehe
btw do you really get a fuel bonus?
The car is in Bris, and should be ready for Sydney pickup around the 10th. That said, it sure feels good to know it's here finally. I don't think I'd import again - a nice 92 model sounds like the ticket! :P
Mark
Cowie.....SSSssshhhhhh.
Just got relocated to Technical Integrity in Army HQ. Something to do with policy and implementation. Over it already. long service in May and home to Qld (brissy) and out of the green.
Hey all, I work for a large Global outsourcing company (EDS) as a Senior Project Planning specialist mainly doing large IT Infrastructure projects. I'm working out of Canberra ATM on Customs and Tax.
What do I really do, Whatever it takes to earn money for the weekends!
its rumoured that i am a panel beater/gearbox repairer,fitter/engineer/welder/fabricator.....just clarifying its not true... i dont know anything about cars.......
Yeah bullshit Troy!!! U built an R34 GTR from scratch, with a piece of sheet metal!!! :wassup:
Also looking for a better position in 3rd level desktop support, 2/3rd level network support... let me know :D
riggap: what area of support are you looking at? I think the position "consultant analyst programmer" is available, not sure if its been filled yet, but I will definately let you know caus we get a $3k headhunting fee at end of probation :D
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
