GTS-t VSPEC or Steve-SST,
which GT30 core do u have now, can u provide the CHRA number?
it might be worth your while to go up to an A/R .82 exhaust housing.
I'll get the number off the turbo tonight and post it up for you.
FATGTS-R, Are you sure it wasn't 650rwhp, cause over here all readings are done in hp. Either way, if you do try and trick the temperature readings on a DD Shootout dyno then the temperatures are shown on the bottom of the page, so it would be obvious to everyone that cheating had taken place. But I do agree that dyno's are just a tuning tool
  • Replies 223
Posted Images
Geniune accredited shootout dynoshave many of the settings you talk of pre set and the temps etc are printed on your print out.
FATGTS-R what is the shops name so we can see if they are one of the accredited shops with the correct software or just the standard issue.
I have now been convinced as to what people have been saying for a long time, Dyno graphs dont mean jack shit.
My car is currently in a Bayswater workshop in VIC getting some mods done.
The workshop in question has a brand spankers DD 4wd dyno.
This workshop together with APS built and developed a twin turbo kit for the LS1 engine.
On there own dyno the car made 460rwkw. On the APS dyno it made 510rwkw both times on RACE FUEL.
The car recently went interstate for a Holden vs Ford gig and won the dyno comp with a ridiculous 650rwkw on PUMP FUEL. Go figure.
The owner of the workshop showed just how easy it is to make a dyno read a lot lot higher than it should.
One example was to "manipulate" the dynos temp sensor for a higher reading in shootout mode.
The next example, and one I did not know about was that supposedly each car that goes onto the dyno is meant to be calibrated so that when the car is doing 100km/h so is the dyno.
He ran the same car twice in a row, one time with the dyno geared correctly and once with the geariing tweaked a tad.
The difference was amazing, the outright power wasnt that much higher, but higher nonetheless but the average power was about 20kw greater all the way across. Overlapping the two graphs you would think they were two different cars.
So to all the people who write "dynos are just a tuning tool and power graphs should be taken with a grain of salt" I 100% agree with you.
This post has been passed on to Dyno dynamics to be sorted buy they say its just some fairy tail some one told some one ,as ppl do.
Actually the car made 688 rwHP at the H v F show, which is almost identical to the 510rwkw on the APS dyno.
Also, Peter from APS himself admitted (on ls1.com.au) that it was NOT on pump fuel, but his "secret APS brew".
EDIT: also, it wasn't in the dyno comp, but only as an exhibition car.
It is very rare those high hp cars run normal 98 rom fuel. Its mostly 100% C16 or 50/50 C16/98
All our dyno comps are done in rwhp over here, and as you can see our readings match up to what they did on the APS dyno, so maybe you should all stop your knocking and try a bit harder:D
I am at 438hp@wheels at 1.4bar on stock internals so i aint that far behind :rant:
Well if you believe your figure then why do you have such difficulty believing ours?
We use Dyno Dynamics dyno's in Shootout Mode, which is the acknowledge standard Australia wide.
Because thats the highest figure i ever got, and realistically its only around 400hp@wheels or even a bit less
Blah dyno reading doesent mean squat unless you can use the power and get it to the ground, and if ya getting wheels spin in third gear then..............
Put all this to rest and run down the damn 1/4 will ya :rant:
Mine will be going on the track soon at Phillip Island and Sandown with the rest of team WANG Victoria to see what it can do in the real world!!
Guest Robo's
I know you allready know this, but Phillip Island and Sandown aint 1/4 tracks, so where is the true comparison???
    • Wrt the engine, you're very much limited by 'production quality' as to how much extra power you can extract from them (I'm talking i6 red-motor) -- a lot here depends on how 'authentic' or 'period correct' you want the modifications to be... ...I'm too old... <grin>...the first true performance engine Holden made, was in the HD/HR models ~ this was the 'X2' performance pack...it came with twin downdraft strombergs on an otherwise unimproved intake manifold, with a two piece exhaust manifold (reckoned to be as good as extractors)... ....these engines were built upon the '179HP' cylinder block, which included extra webbing in the casting to make it stronger and less susceptible to block distortion... The next performance i6 came out with the HK Monaro (also found it's way into the LJ GTR Torana ... the car I wish I hadn't sold)...it had pretty much the same manifold setup, but was built against the '186S' block...this block retained all the extra webbing of the 179HP block, but added a forged steel crankshaft (instead of the stock cast crankshaft), because it was possible to snap the crank... ...apart from the inherent weaknesses in the stock (cast crank) blocks, the next limiting factor is the cylinder head porting & combustion chamber design, and the actual valve sizes. Back in the day, you could buy a 'yella terra' cylinder head (from stage 1 to stage 5 gradients), and this was the way to get serious power out of them -- with the extra breathing of these heads, you could fit a triple SU or DCOE Weber setup... ...obviously, these mods were a waste of time on a stock cylinder head/camshaft grind. My housemate rebuilt the i6 in his VH dunnydore about 6 months back -- this is a 186S block with the 12port 2850 blue motor head and intake/exhaust manifolds, with a dual throat Weber off an XF Falcon mounted on an adapter plate ; it's not a bad makeup...got more torque & fuel economy just light-footing it about on the first throat, but stand on it and it makes more giddy-up than the standard 2850 blue motor that it replaced. Personal note: I'd just fit an RB30 and be done it it 馃槂
    • Thanks for sharing. That's a great video! My buddy is doing the same thing on his build (S chassis struts and towers). He's building an S14 with billet RB30 shooting for 2000whp... a race car with a TH400 just like this video. For a road car I just couldn't go this route as the strut has to be almost vertical and the caster is not going to pivot correctly (let alone camber gain). You think the R32 frontend is bad, wait till you put a MacPherson strut on without modeling it all in Solidworks to check geometry. I'm not saying it's a bad way to do it but I'd be really curious to see how it affects the geometry.
    • Hey Christof and welcome!  Sounds like an awesome project! I'm not sure many of the regular users on here would know much about the HK but I could be wrong.  Looking forward to updates.
    • As long as its NOT a HyperSHITtune, youll be fine.
    • First time visitor and currently getting ready to start work on my HK Premier.  Its all stock, 186 with 3 on the tree.  The only mod i have right now is extractors.  I am hoping to get some guidance on slightly modifying the engine to bring a little more power. Just going for a nice, comfortable cruiser.  The car is very straight, however i have been out of the country for 20 years and its been gathering dust at a family farm.  Will be doing quite a bit of body work to cut out some small rust areas (frnt quarter panels and a few other small bits) and fix up the paint.  Will be redoing the interior (its currently black and the seats are in real need of recovering and respringing the driver side (its front bench seat).  The dash needs a little TLC, but no real damage.  As my heater has degraded I am considering fitting something after-market that will be both heater/AC (recommendations here are always welcome). Wanting something discrete that will allow me to use the same controls and not be obvious once inside the car.   For the engine, i have been told i could consider upgrading my cam (imagine i would need a new head as well) and putting a new carby (currently the original stromberg).  However not sure what is going to be the best route.  Would certainly welcome any comments/suggestions.  As  a final step I am looking at changing the wheels. Current hubcaps are in dire need of refurbishment or replacement (imagine its a bit like hens teeth).  Thinking of some clean/classic looking mags (7-inch should be more than enough - not going for a large change in look).  Welcome any comments/advice and of course any questions.
