i need some advice....
I am looking at changing a pair of turbo's on an RB26 as i want to get rid of the ceramic wheels. Now after doing the conversion i dont have heaps of cash and was wondering if there was a turbo, ie S14/15 T28 or similar, with steel wheels that may bolt straight up to the RB26 manifold and coolant/oil lines without costing an absolute fortune... i dont mind re-doing inlet pipework, but not really interested if it needs much more than that....
now before anyone tells me i shouldnt have done a conversion if i couldnt afford it blah blah blah it is more of a play safe thing i am thinking of doing rather than a have to do it cause i have lost the turbine wheels and got stuck out the back of whoop whoop with turbo problems..... and at the same time i am hoping the car can make some more reliable power :P:D:D
any help or recomendations would be greatly appreciated. if possible what sort of power levels have been made or could be expected would also be a help.
Alternatively i am open to offers of someone pointing me in the direction of some standard sized steel wheel turbo's that may be for sale.
Thanks Brad
https://www.sau.com.au/forums/topic/49224-rb26-turbo-advice-needed/
ido09s,
a friend of mine has a pair of GTR N1 turbos which have the larger steel turbine wheel along with the larger compressor wheels and larger housings for sale.
awesome turbos for the street.
PM me if you're interested.
Nengun has HKS GTSS kits at a very reasonable price. Obviously no where near as cheap as second hand turbos, BUT they are brand new, ball bearing steel wheel HKS turbos - would be very nice at that money...
Richard
As an alternative you can get your turbos fitted with slightly larger steel turbines. Most people do the compressors at the same time, basically the spec is pretty much N1. Cost about $1,500, plenty of turbo shops do it, we use GCG.
Hope that helps
Thanks for that Sydneykid, i rang them the other day to get a quote for somethig like that. You must get pretty good rates with them cause they quoted me $1850 x 2 for new cores which is all they can do for me. Given that i would sooner spend the extra cash on some T517Z's and a retune from Advan :(:D:D but cash is my limiter at the moment :(:(:D
nengun currently have the GTSS kits for around the $3300 mark which i pretty cheap as long as you dont get stug by duty and GST
$3300?
Heres a link more indicative of the landed price.
http://www.nengun.com/product_info.php?pro...a0d38f7f9712a2b
Once you factor in the cost of fuel pump, injectors,ecu and labour charges(avg $1000 to remove and refit)and tuning the dollars go up.
My 2cents
If your on a budget get yours rebuilt with standard size steel wheels for around $1800(pair)
Boost response won't be as good but you'll be able to run over 1 bar without worrying about the wheels falling off.
Thanks for that Sydneykid, i rang them the other day to get a quote for somethig like that. You must get pretty good rates with them cause they quoted me $1850 x 2 for new cores which is all they can do for me. Given that i would sooner spend the extra cash on some T517Z's and a retune from Advan :D:D:D but cash is my limiter at the moment :D:(:cheers:
That's about right for a core swap to ball bearing/water cooled, but that's not what I was describing. They stay plain bearing/oil cooled for ~$1500 (yep, that's for the pair).
Hope that clarifies :(
I think turbo tax was 5% when I imported turbos, so unless its gone down to 3% that site is wrong (but I also purchased my turbos from him)
Dont forget customs fees ontop of the tax and gst.
And make sure you get all your gaskets from him, Mine came with 2 short and ended up costing me an extra $70 from nissan
Not complaning here.. he provides a good service and price, just giving some tips
Just - the car already has pump, injectors and an ECU so upgrading bits like that arent a worry :D:)
sydneykid - when i rang GCG the other day they told me all they had was exchange cores..... i told them i just want steel wheels put in the stock turbos and they said they dont offer that service, they only do core swaps so damned if i know what shit they are spinning......
i spoke with Peter the other day and i think we will follow his advice and just wait till they give up, if they give up.... by the time i spend cash on steel wheels or different turbos i am $1000 closer to the T517Zs i wanna put on the car after tunign and all thelabour involved. Thanks for all the info guys, it has been much appreciated.
Now to find a thread on here from someone who has fitted Trust T517Z turbos to an RB26 :(:D:D
Brad,
Are you looking for a turbo with good low down response for the street? if so I wouldnt be looking at the T517Z.
I have had a ride in a car fitted with these turbos and was less than impressed with the response. For the money you would pay for t517z's, im sure you could find a good set of used 2530's or N1's - if not a new set of GT-SS turbines.
  • 3 weeks later...
How about getting N1 turbo's rebuilt? These were in the GTR32 when I got it and the front one has started to scrape the case, Bearings worn out from lack of oil changes!from last owner.
I like the response from these turbos.
Any ideas, short on cash at the moment and want to find out what my options are.
  • 2 months later...
