Expression of Interest: – Private track day at Queensland Raceway.
I’ve been in contact with the lads who run QR, and they are sending me out some info on price’s and details to have a private day.
So at the moment just a show of hands of who would be interested pending price/date.
Also a show of hands with who would rather a catered lunch apposed to BYO food. Once again this is pending price, just after a rough idea of who’s in.
Note; This post will be updated with all the maybes to make it easy to follow, so please post your name and what you drive, so I can list you.
Cheers, Josh. :P
Maybe's as of the 22/08/04
1. Nismo Boy (Josh)
2. Ian
3. Knore (Micheal?)
4. Melv
5. Slamm
6. Nismo33 (Ardee Den)
7. NA R33 (John)
8. Shane
9. 33Niz (Matt)
10. Team Krazy (Neil)
11. Predator (Gordon)
12. MicK51 (Mick)
13. Maccattack (Peter)
14. Jlnewton (Jason?)
15. Wados (Wade)
16. Rb26dett (Tze)
17. 51jay (Jay)
18. 4doorz
19. Yoparata (Aaron)
20. Slapper
21. Owned (Nick)
22. Smoothline (Matt)
23. Lazy-Bastard (Warwick)
totally. My biggest problem is getting hold of a helmet. while i still have mods to do i baulk at spending money on a helmet. can you hire etc.. or buy really cheap 2nd hand ones? they're probably only like 100 bucks or something right?
This isnt a QR open day once a month... This will be a private day, with just us on the track.
yip there is one every 6 weeks
i am going tomorrow. anyone else coming? or do we have a few timing belt and spark plug issues like last time :lol:
its not like me to poke fun at ppl, but it pisses me off when ppl are all talk and have big mouths and then when the day finally comes 2 ppl rock :shakeshead:
u can hire helmets at the track, its around $10 i think but u need to buy a hair net to for $5?
This sounds very interesting, i might even race my car now that i have a new diff. And yes TeamKrazy, u can guaranty my dad will be interested in this. Might even have the race car ready! :P
Yep, I'll be there tomorrow.
Also very keen for a private day. Let us know the details.
    • Hey y'all, I have a completely stock 1991 R32 GTR, yesterday I took my car out and went for about a thirty minute drive. It was fine on the way there but when returning home I think the car might have gone into a limp mode. I was cruising in 5th gear around 130km/h, the hicas light came on and there was a significant loss of power. About a minute later I hear a thump, the car starts driving normal again and is fine the rest of the drive back. This is the second time its happened, same as now it was fine on the trip there. On the way back it had the hicas light on but that time I would feel the power going in and out before hearing the same thump and it being fine.  I have no idea idea what causing this, but if anyone has any ideas it would be great as a start chasing the cause of this. Also I can provide more details if needed. Thank you
    • When sanding across a convex panel, you need to sand, as much as possible, at right angles to the curve. If the panel is compound convex curved (ie curved in both directions) then you are SOL and have to use "craftsmanship" to get it right.
    • Today in Skyline arts and crafts!! I’ve made some progress.    had to put extra notes in there so I don’t stuff it up 😂
    • This sounds like me. And then why I leave shit that I had previously hobbled together broken. Lately I've changed strategies to "If I don't want to justify the money on decent stuff, I'm not going to justify hobbling it together". I'm still for DIY, but DIY it properly is more my thing. However, I am terrible on not setting up backups still... Which reminds me, I need to go backup some of my work VM machines... Oh, it's also why I've become a lover of building things into Docker Containers... Then I just need a machine that can run docker, and bam, that specific system is up and running, on the specific versions of everything I need for it to run (In the event a change in required software version breaks something else). Also, these days, my steep learning curves are spent with work related stuff, and on very varied projects, that my want to do other random projects like build a dashboard for my own car has dwindled away to "I just want the car running", which is my current PITA, as I'm getting the Landcruiser usable again, and it has just been non-stop the past 6 to 8 weeks of buying parts, and working on it. Oh, and tools that are meant to be fit for purpose... And they break, because 25 year old 4WD decides it's stronger... But by the time I have it ready to roll back out the drive way, nearly all the stuff in it will have been touched and serviced, so the damn thing better give me NO FREAKING ISSUES, for at least the next 50,000KMs! Just redone whole front of the motor, and resealed the up top stuff, replaced a bunch of things getting perished, new timing belt done, water pump, lower timing cover (Toyota diesel engine runs timing GEARS for the bottom half the motor, and a timing belt from halfway up to the top), new harmonic balancer, fix up the alternator, new thermostat, full swivel hub rebuild, new bearings and seals front and back, steering box rebuild, new battery, and today, it turns out a rear shock has let go, so four new shocks are about to go on order, and that will leave me with after the next run of work, to see if I need to order just a brake caliper re-seal, or if I'll need new pistons in them too. Oh, and I'll finish welding in the new floor sheet metal shortly too. Presently I just want it finished already... But once all the above is done, I still need to fully service diffs, gearbox, transfer, and motor. Then flush and bleed the clutch, and flush and bleed the brakes. But enough about our waffle, back to Duncan's heat problems... I think for Duncan he just gets a thermoswitch, and a manual switch to run some water misters. Thermo so it's only on above certain temps, and the manual switch so it can be turned off even if it is above certain temperatures. IE, switch on for "I'm now on track", then it doesn't need any "smart" computers that might try and do things wrong. And switch the thing off completely on the cool down lap, so when he stops in pits, there's not even a possibility of it dripping any water out to get him in trouble.
