I have had conflicting opinions from different tuners as to the recommended run-in procedure for a freshly rebuilt RB26:-
1. bed in rings on a dyno, then light tune & run-in over 5000klms
2. no dyno, lock Power FC at 4500rpm & run in on street over 3000klms
Both agreed on run-in oil, low boost etc however number 2 said a dyno is not a good option first up - any ideas!?
https://www.sau.com.au/forums/topic/49284-bedding-in-rings-recommended-option/
my opinion is number one, since on the dyno you can load up the engine as much as you want (and rev it as high or low as you want at that load). i know people who have done this and had no trouble. some people go to the trouble of putting a lot of weight on their car (towing etc) so they can increase the load to bed rings in - but a full load run through 2nd gear even to 4000rpm is probably hard to do, especially without speeding.
however this is just my opinion and i've never rebuilt an engine myself.
Just take it easy for the first 3 - 6 thousand k's always changing RPM, when first start is done drive for a bit at different revs then load it up a hill with your brakes on a couple of times. never drive at a constant rpm and dont rev hard.
You dont want to thrash it with the running in oil becuase its shit oil and will carbonise easier then normal oil causing seal damage on your Turbo.
All the motors we rebuild and some have made over 600HP for more then 2 years have been fine with this method.
BR,
JH
oh and another thing have your tune spot on so your not using to much fuel as to not 'petrol wash your bores'
*yeah i know this can happen at any time its just a warning for somebody who has just invested in a rebuild*
BR,
JH
BR,
JH
Mobil1 synthetic in it to start, run it in on the dyno and tune it up
Drive it for a 1000km's and change the oil.
if all looks good dont worry, and those 1000km's dont have to be ***** km's underload up hills and all that crap.
Just get out there and enjoy it. After the first 1000 go crazy.
Complete opposite of what you should do... synthetic + brand new engine = dead engine before too long
my motor has just recently been built...ive got 1200kms on the clock...within this ive had 3 dyno tunes with full boost and a run at wsid......i had the same problem in deciding ....but what i feel is very important is dont use to thin of an oil to run it in....i was a bit hesistant to open her up in the first 300kms but what i did was gave it a tune to 6000rpm...she responded well.......it is also very important that ur mixtures arent too rich (mine is 12 flat) as the extra fuel will glaze the bores.....once u feel confident open her up... :headspin: :headspin:
i had no doubt no-one would be able to accept that.
but ask the major manufacturers what tehy use... i think you'll find its synthetic.
Dont see the holen V6 dying before too long
Not dead engine you just wont bed the rings in an she'll burn oil.. Not blue smoke out the back either you will just be down on oil all the time..
*The above depending on how bad the rings have not bedded in.*
I give a safe 300 - 500kmhs then open her up
BR,
JH
none of the motors ive seen here in Vic are blowing oil, and lots have been running for years.
and some of these motors are cracking 400+awkw all-day everday in GTRs that regulary get flogged around the local circuits. Nothing im going to argue with at all.
each to thier own on this issue.. its just like BOV or no BOV.
I ran mine in with synthetic. It also had a whole load of power runs as its "run-in". Sorry but all this bullshit people speak about run in is garbage, my motor was run in at full ball with a synth oil and about 4000k later its not burning oil and running like a psycho.
BTW this isnt an attempt to argue i couldnt give two ****s whether anyone believes me / wants to argue or whatever just thought it might help someone.
raist60,
I'd agree that an engine need not burn oil and run poorly if run in on synthetic if run in hard. However give me the same engine and mineral oil run in and I'll show you a motor with better compression and power every time (not to mention how much longer it's rings are going to last). The object is to get the rings to 'bite' nicely into the honed surface (a good surface hone is critical also). Synthetic oil like mobile 1 is so good at reducing the friction so it's never going to allow the kind of wear a 'run in' mineral oil will.
Ya, same from what ive seen, but with motors well over 20thou km's on em.
Nothing wrong with em yet.
When is the actual point when the rings bed just to add to the thread :)
Bl4cK32 No, but ill have to pay for my own, and considering it'll be money outta my pocket if its stuffed would kinda make sure that how mine is being done... is going to be a way that works.
but it doesnt worry holden or ford, so it doesnt worry me either
who has ever bought a brand new car and had to dump the oil at 1000 or whateva cause mineral or running in oil is used from the factory in your new car, synthetic straight up, why make your engine "wear in" ? just out of interest, buy a brand new porsche, mercedes HSV and see whats in it.... mobil 1
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
