most manufacturers run their engines in on an engine dyno before they even see a car... from memory mitsubishi here in adelaide run it for almost 20 minutes at varying load/rpm points and then give it a few runs the redline. this is purely because people don't expect to have to treat the car specially when its new to run it in.
thats probably why they can specify synthetic straight away - while the motor may not be 100% run in, the vast majority of the running in process should be done by the time you get the car.
We are in the middle of running in a freshly re-built motor now, And from what we know the first 500k’s is with running-in oil and then change it to synthetic from their on.
We have just clocked 680km and done an oil chance with synthetic and you notice the car running lots smoother straight away with the new oil, compared to the running in stuff.
Haven’t had any problems with compression or loss of oil. Everything seems to be running ok.
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
