Guy's i've come across a T04e turbo at a nice price. I don't know anything about them. Could someone please fill me in on how they respond with RB20DET's etc.. here is the specs of the snail:
3" INLET DIAMETER
2" OUTLET
WET FLOATING BALL BEARINGS
1/8 NPT OIL INLET
T3 Flange type
SPECS:
.57 T COMPRESSOR WHEEL
.50 A/R COMPRESSOR
.63 A/R TURBINE
Stage 3 Wheel
https://www.sau.com.au/forums/topic/49287-t04e-turbo-to-suit-rb20det/
They are a cheap  Copy of a Garrett Turbo ,, and from all reports they dontlast  Very long .. There is no such thing as wet floating bearings they are just plain bearing and not watercooled ,,  i would spend my money on some with a good brand name ..
dude,
garrett are the ones that brought out the T04E range.
gtst,
that seems like a pretty nice combo for a street car.
the 57T T04E comp wheel is quite good as it has quite a large efficiency island, which would work quite nicely with the A/R .50 comp housing.
btw, it can also flow enough air to produce ~400bhp (providing the exhaust wheel can flow well enough aswell)
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
