Hey people just wondering if anyone has any info on the old Mazda 808 sedans?
things like engine type and potential? suspension tunability? and possible problems that these thing might always have!
just looking into a little project car and have seen these things go really well, so could be a fun car to do up in spare time.. for track/drift fun :(
any and all info would be great!
https://www.sau.com.au/forums/topic/49326-mazda-808-questions/
heaps of my mates have built up old rotaries
i am also building an 808 atm.
one thing u need to know about these cars is that the reason people build em to go fast in straight lines is becuase that really all they can do.
they handle like boats and cant be lowered very much unless you tub the rear.
the only engine you should go for if you want it to go hard is a rotor.
If you can get it to handle nicely to start off with then go for a 13B bridge port.
Why not go turbo? because with the bridgy it can be cooled easier and more efficienly. and in an 800kg car 150-200hp is pleanty of power.
cheers 2GU UP 2, will keep looking into this... thanks for the tip! i have seen one going really well around the track without tubes running really skinny tyres with an n/a rotor.. havent seen it for a while, might see it tomorrow at wakefield and check it out!
Beg to differ on the turning corners theory...If they turn corners that badly why are they used succesfully in the club car arena??? They can be made to handle, but i f u want an early rotary that handles well the RX2 is the pick of the bunch, coil overs on all corners, handle really well!!
Extremely light cars, cheap to purchase initially, cheap to modify and get reliable power, cheap to maintain (in comparison with other club cars). You cannot get a naturally aspirated piston powered car to produce the same horsepower to cubic capacity without spending a bit of coin, not to mention the weight of the motor per cube. Datsun 1600 gets close, but is going to be down on power unless you get a twin cam engine.
All early rotaries have a strut front end which dicate a coil-over shock suspension. RX2's have a multi-link rear end with a solid axle, it wasn't until the RX7 was released when they re-introduced the watts-linkage rear end. Discounting the behemoth RX5, useful only as a boat anchor and a source for 13B motors. Oh and the rear discs. Off the top of my head RX2/Capella's weighed in at 960kg, where the 808/RX3 was 880.
Chris, you really want to stay in the nissan family, right? try a 1600, 180b or 200b sss :D
i've got a mate that has a 120Y rally car, but those dont really interest me.. 1600 are still expensive cause everyone wants them to do up with SR20 or CA18..
Dough Boy, nice info and food for thought.. i was going to get one really cheap but that fell through so looking around for something different and cheap to pass the time with!
If anyone sees one real cheap let me know :(
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
