I know there has been other post on spark plugs, but i'm still a bit confused....
A number of plugs have been recommended, but i'm not sure which type to use.
My car currently has NGK-R BKR7E 11
Is this the right plug for a stock RB25DET running stock boost?
only mod is a 3" exhaust with dump pipe.
Repco recommended NGK-R PFR5G-11
what is the correct gap?
Any help would be apreciated
https://www.sau.com.au/forums/topic/49351-spark-plugs-for-r33-gtst/
I just changed spark plugs last week. Using NGK BPR6ES-11 These are just standard copper plugs
Was a bit of a pain to change since i didnt really have the right tools though.
I gapped them down to 0.8mm
Everything runs fine.
Edit: (A year later 16/5/05)
Turned out that everyone is not fine. Since that time, ive added a fmic and boosted it. After a few weeks i started to get misfires under load. I thought that it was my sparkies going out, so i replaced them (with the same bpr6es). But unfortunately, the problem still existed.
Not knowing what the problem was, took it down to a reputable mechanic who discovered in the end that all along that the bpr6es were the wrong spark plugs for the rb25. Physically, they are bigger and longer. Turned out that it was squashing the spring tensioner inside the coil which caused the misfire somehow.
Anyway, no serious damage afaik. The spark plugs youre meant to use are NGK BKR7E-11 (or maybe another heat range if you prefer, gapped down if needed)
Compared side to side, the new plugs are smaller and is the samel size as the ones that came with the car when it first came from japan.
Goes to show that you shouldnt believe everything you read on the forums :(
Anyway, ill report back if there are anymore issues with the plugs
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
