I know there has been other post on spark plugs, but i'm still a bit confused....
A number of plugs have been recommended, but i'm not sure which type to use.
My car currently has NGK-R BKR7E 11
Is this the right plug for a stock RB25DET running stock boost?
only mod is a 3" exhaust with dump pipe.
Repco recommended NGK-R PFR5G-11
what is the correct gap?
Any help would be apreciated
https://www.sau.com.au/forums/topic/49351-spark-plugs-for-r33-gtst/
I just changed spark plugs last week. Using NGK BPR6ES-11 These are just standard copper plugs
Was a bit of a pain to change since i didnt really have the right tools though.
I gapped them down to 0.8mm
Everything runs fine.
Edit: (A year later 16/5/05)
Turned out that everyone is not fine. Since that time, ive added a fmic and boosted it. After a few weeks i started to get misfires under load. I thought that it was my sparkies going out, so i replaced them (with the same bpr6es). But unfortunately, the problem still existed.
Not knowing what the problem was, took it down to a reputable mechanic who discovered in the end that all along that the bpr6es were the wrong spark plugs for the rb25. Physically, they are bigger and longer. Turned out that it was squashing the spring tensioner inside the coil which caused the misfire somehow.
Anyway, no serious damage afaik. The spark plugs youre meant to use are NGK BKR7E-11 (or maybe another heat range if you prefer, gapped down if needed)
Compared side to side, the new plugs are smaller and is the samel size as the ones that came with the car when it first came from japan.
Goes to show that you shouldnt believe everything you read on the forums :(
Anyway, ill report back if there are anymore issues with the plugs
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
