Help Please with profec B spec II
jaqule
 Share
If someone could please give me a hand some time this week to help me install this before the dyno day on the week end ....REWARD.... to be discussed on the day . I also have a duel piller mount with a boost gadge and oil temp if you have time .
I really need help on this , I have the instructions for both in English.
thanks in advance Beau :(:D:D:cheers:
I can give ya a hand sometime Beau...
Profec B, pillar mount and boost guage should be easy enough...
Oil temp guage should be easy to fit and get power to, but if it's a mechanical sender, you might need a different fitting for it... We can check it out either way...
If my pipe arrives in time, we could maybe do the swap over for that too...
hey boys, girls and lovers of the sweet sound of a whistling turbo. i am with mr. j_isnoll. it would good to get out on a cruise. and i agree with the macca's call. there food only tastes good when you are starving and it is the only thing open. plus; the whole let's meet at macca's on a certain night of the week thing was killed along time ago in many locations by the cops ( damn those anti-hooning laws). if a few people turn up it should be good.
ps. peace out to squizz. i bumped into him and a mate in his slick silver 32 GTR at qut a while ago.
and for the record i haven't lost my licence yet. YET?? speeding is so tempting when you have a skyline under your right foot.
japtaxi.. no it sticks out all the time.. i helped somebody install the spec II version, its a pain in the ass.. and its all digital
the spec I was a doddle to set .. they go cheap.. probably exactly the same thing too.. fark the rice :)
 Share
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
