If someone could please give me a hand some time this week to help me install this before the dyno day on the week end ....REWARD.... to be discussed on the day . I also have a duel piller mount with a boost gadge and oil temp if you have time .
I really need help on this , I have the instructions for both in English.
thanks in advance Beau :(:D:D:cheers:
https://www.sau.com.au/forums/topic/49364-help-please-with-profec-b-spec-ii/
I can give ya a hand sometime Beau...
Profec B, pillar mount and boost guage should be easy enough...
Oil temp guage should be easy to fit and get power to, but if it's a mechanical sender, you might need a different fitting for it... We can check it out either way...
If my pipe arrives in time, we could maybe do the swap over for that too...
hey boys, girls and lovers of the sweet sound of a whistling turbo. i am with mr. j_isnoll. it would good to get out on a cruise. and i agree with the macca's call. there food only tastes good when you are starving and it is the only thing open. plus; the whole let's meet at macca's on a certain night of the week thing was killed along time ago in many locations by the cops ( damn those anti-hooning laws). if a few people turn up it should be good.
ps. peace out to squizz. i bumped into him and a mate in his slick silver 32 GTR at qut a while ago.
and for the record i haven't lost my licence yet. YET?? speeding is so tempting when you have a skyline under your right foot.
japtaxi.. no it sticks out all the time.. i helped somebody install the spec II version, its a pain in the ass.. and its all digital
the spec I was a doddle to set .. they go cheap.. probably exactly the same thing too.. fark the rice :)
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
