Interesting, considering Newtons is a measure of force, while Newton metres is a measure of force & leverage.
'100N to a Nm'??
1 newton applied to a lever 1 metre from the fulcrum is 1 Nm.
Diameters of tyres, what gear you're in, diff ratio, etc all would be part of the equasion
*can of worms initialised*
*confusion pending*
A Newton is defined to be the force which will change the velocity of a one kilogram object by one meter per second over a period of one second.
Who uses newtons on a dyno? You should be given a torque reading in Netwon-metres. The only thing i think you could do is multiply the force in Newtons (6000) by the radius of ur wheels (about 0.30m?) to get a torque of 1800Nm, but that doesnt sound right.
Yeah it's a bit confusing, isn't it :D.
Basically, they're saying you can't directly convert them as they are measurements of different things.
The dyno is reading tractive effort/force from memory, so I don't think there'll be an easy way to do a conversion.
The way I work out torque from dyno graphs is to get the power and the rpm (you will have to convert this from the km/h reading - compensating for the diff ratio and gears), then use this formula:
Torque (Nm) = Power (kW) x 9543 / RPM
would like to know how to convert newtons to newton metres. just got my car back from CRD after a dyno tune and made just over 6000 newtons at the wheels, just like to know what that is in newton metres
To convert Newtons to Nm from a Dyno reading, you need to know the roller radius, which is 108.5mm on the dyno mentioned.
Just muliply 6000 times .1085, and this will give you your peak Nm reading.
Your car had a maximum Nm reading of 651Nm in this case.
Newtons, or Motive Force which is the correct name, is the force at the tyre diameter pushing the car forward.
651Nm is pretty high. Over double stock - and that's at the wheels. Are you sure that's right? He would have to be making his max of 258kW at 3800rpm to get that much torque, and I'm sure he would have reached peak power much higher up than that.
Maybe I've screwed up my calcs or something.
ok looked it up:
So if your car can force 6000 newtons, this would equal 6000 newton meters.
To further explain this your car can basicly push 6 tons of weight 1 meter at full power.
A newton is the amount of force nothing to do with torque, the weight of 1 newton is the same as 100 grams.
A Newton Meter is the amount of 1 Newton (100 grams) being moved 1 meter in any direction.
Another example would be picking up 100 gram weight, and pushing it 1 meter, you can then say your arm has 1 newtonmeter or 1nm.
Great isn't it???? :)
Did you say 'can of worms' funky....
As funky said a Newton is the force to change the velocity of a 1kg object by 1m/s/s. In other words its a accelerative force. Force = mass x acceleration
Gravity on Earth can accelerate objects at approx 9.8m/s/s. That means my 98kg arse puts a force of 960.4 Newtons on the ground (98kg x 9.8m/s/s).
If I was standing on a big breaker bar 50cm (0.5m) from the socket/wheelnut trying to undo a wheelnut, I'd be placing 480.2 Newton metres of torque on it (960.4N x 0.5m).
This is a very simple overview of Newtons (force) & Newtonmetres (torque).
If you want to start talking in terms of force applied moving an bjet a set distance then you are really opening a MASSIVE can of worms. For 1 it's incorrect and 2 you're forgetting about inertia, momentum, friction, acceleration and a few other concepts that i've forgotten abut in the last few years, not to mention the infinite variables that would render this method of measurement absolutely useless.
Cul202 has the right of it theory wise, that is Newtons is a measurement of force, ie Force =mass x acceleration, metres is a measurement so newton metres is force x distance, also known as bending moments or torque.
how to get a proper torque figure from a figure of 6000N is beyond me i'm afraid
1 Newton is the weight of the object on earth. Force of gravity on earth is 9.8m-1 and the physics formulae u guys are looking for is
W= mg. W= Wieght (in newtons)
m = Mass (in Kg)
g = gravitational force (9.8ms)
so... YOU CAN DO THE MATHS COZ IN TOO FREAKIN LAZY
That's why I just use the torque curve given on the dyno purely for seeing how your torque curve looks - I ignore the values. If you want actual values (like I think the original poster wants), then you just use the formula I posted earlier.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
