the proxy at work wont let me look at that..
anyone give me a rundown?
This is what is says
Make: Toyota
Model: Sprinter Trueno AE86
Gear: Version 2 Specs:
ECU/Engine/Exhaust
AE101 Wagon Engine
(Final Production Release, TRD Group A based engine)
TODA 288 Degree Intake & Exhaust Camshafts
TODA High Tensile Valve Springs
TODA Adjustable Cam Gears
Port & Polished head
Quad Throttle Body to Air
TRD Engine Mounts
TRD 0.8mm Racing Head Gasket
Revolver Full Aluminium Racing Radiator
Carbing Radiator Overflow Tank + 1.1bar Radiator Cap
Cusco Oil Catch Can
Custom BEL Garage 19 Row Oil Cooler
NGK Iriway 7 Spark Plugs
Honda Type-R Ignition Leads
Microtech LTX-8 ECU
Sequential Fire Coil Packs
Compression ratio - 11.9:1
Suction and Cooling
Revolver Aluminium Radiator
Earl's 19 Row Oil Cooler Kit
Davies/Craig Electric Thermofans
Throttle Body Filter Socks
Drivetrain
TRD 2 Way LSD
4.3 Final Gear
JDM T50 Gear Box
TODA Racing 3.7kg Chrome-moly Flywheel
Exedy 3 Puck Brass Button Racing Clutch
Handling
Disc Brake Rear End Conversion
Spirit Rear Brake Discs
Mugen Front Brake Discs
Mazda RX7 Caliper Conversion
Custom Coilover Conversion
Tokico HTS Dampers
KG/MM S21 Racing Springs
Safety 21 6 Point Roll Cage
Interior
Defi Tachometer + Shift Light
Defi Oil Temperature Gauge
Defi Water Temperature Gauge
Defi Fuel Presssure Gauge
Exterior
JDM Spec Trueno Front End Conversion
Full bare metal respray in Panda colour scheme
Watanabe 14 inch rims with Dunlop FM901 street tyres
  • Replies 101
    • Yep that's a superb price and ther is no way you will over capitalise on you investment.  As to the bracket, again just use the passenger side seat  bracket ( obviously reversed ) as a sample to reshape it and in this case, TIG it back together.
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
