>> 1995 R33 Series 1.5 (Brisbane) <<
By drifter17a · Posted
So unsafe would you say now? little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting -
Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this -
No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply -
I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
