4bella Posted August 22, 2004 Share Posted August 22, 2004 Just wondering if anyone knows or has any ideas about this loud whistling noise that goes on for 2 secs straight after my car has turned off.... i try hearing where it comes from and its definately near the turbo/manifold/compressor area....was thinking it might be the bearings....but my t28 turbo runs perfectly and boosts up properly and even on high boost.... Link to comment https://www.sau.com.au/forums/topic/49399-very-loud-whistiling-noise-in-engine-bay-once-car-has-been-turned-off/ Share on other sites More sharing options...
Sydneykid Posted August 22, 2004 Share Posted August 22, 2004 Air leak? Link to comment https://www.sau.com.au/forums/topic/49399-very-loud-whistiling-noise-in-engine-bay-once-car-has-been-turned-off/#findComment-986776 Share on other sites More sharing options...
WazR32GTSt Posted August 22, 2004 Share Posted August 22, 2004 turbo still spinning and slowing down maybe... ? is it ball bearing? Link to comment https://www.sau.com.au/forums/topic/49399-very-loud-whistiling-noise-in-engine-bay-once-car-has-been-turned-off/#findComment-986959 Share on other sites More sharing options...
Cubes Posted August 22, 2004 Share Posted August 22, 2004 I had a really loud whistling noise once the car warmed up once. Popped the bonnet couldn't see anything. It was a pin hole in the top radiator hose. What I found interesting is at first there was no signs of steam. Just a damn loud whistling noise. Link to comment https://www.sau.com.au/forums/topic/49399-very-loud-whistiling-noise-in-engine-bay-once-car-has-been-turned-off/#findComment-987126 Share on other sites More sharing options...
The Mafia Posted August 22, 2004 Share Posted August 22, 2004 Just wondering if anyone knows or has any ideas about this loud whistling noise that goes on for 2 secs straight after my car has turned off.... i try hearing where it comes from and its definately near the turbo/manifold/compressor area....was thinking it might be the bearings....but my t28 turbo runs perfectly and boosts up properly and even on high boost.... mine does this too.. Sounds liek the car is sucking back or something.. Not sure but I'll monitor this thread and let you know if I find the problem. Its just as you shut the motor off right? ass soon as it stops you get a suck back kind of noise? Link to comment https://www.sau.com.au/forums/topic/49399-very-loud-whistiling-noise-in-engine-bay-once-car-has-been-turned-off/#findComment-987435 Share on other sites More sharing options...
krzysiu Posted August 25, 2004 Share Posted August 25, 2004 I have it too. But its just the POD filter spittin the rest of the air out. Just makes a "shhhh" noise when turning off the eninge. Link to comment https://www.sau.com.au/forums/topic/49399-very-loud-whistiling-noise-in-engine-bay-once-car-has-been-turned-off/#findComment-988377 Share on other sites More sharing options...
drunkenmaster Posted August 25, 2004 Share Posted August 25, 2004 Is your coolant/water low by any chance? Link to comment https://www.sau.com.au/forums/topic/49399-very-loud-whistiling-noise-in-engine-bay-once-car-has-been-turned-off/#findComment-988402 Share on other sites More sharing options...
4bella Posted August 25, 2004 Author Share Posted August 25, 2004 It sounds just like a kookaburra. no joke, i know it sounds weird and funny but it sounds just like it and goes for like 2-3 seconds...even whe im just idling at the lights waiting...it sometimes goes off again....its definately near the turbo area.... Link to comment https://www.sau.com.au/forums/topic/49399-very-loud-whistiling-noise-in-engine-bay-once-car-has-been-turned-off/#findComment-989191 Share on other sites More sharing options...
bless_you Posted August 25, 2004 Share Posted August 25, 2004 sounds like you could have a faulty idle or thottle sensor causing the drop in RPM when you are idleing... i have the same thing happen. may be a loose belt? havent had the time to investigate my noise though. Link to comment https://www.sau.com.au/forums/topic/49399-very-loud-whistiling-noise-in-engine-bay-once-car-has-been-turned-off/#findComment-989337 Share on other sites More sharing options...
Duncan Posted August 26, 2004 Share Posted August 26, 2004 It sounds just like a kookaburra. no joke, i know it sounds weird and funny.... Are you sure you didn't suck a kookaburra into your engine while you had the air filter off? That would cause a kookaburra noise. I think it happens a lot with the bonnet scoop on the WRX sti as well, birds and small children often get sucked into the engine Link to comment https://www.sau.com.au/forums/topic/49399-very-loud-whistiling-noise-in-engine-bay-once-car-has-been-turned-off/#findComment-989888 Share on other sites More sharing options...
BBQ Posted August 26, 2004 Share Posted August 26, 2004 Check your belts, eg, alternator, power steering, A/C if all are ok maybe your timing belt pulley is seising up, it tends to try and jump off the pulleys on down revs, How many km on the clock? if 100,000km it will be due for timing belt change. Link to comment https://www.sau.com.au/forums/topic/49399-very-loud-whistiling-noise-in-engine-bay-once-car-has-been-turned-off/#findComment-989922 Share on other sites More sharing options...
