Hi guys
Recently the radiator on my RB25 Silvia died, and assuming it was an R33 radiator, i got a replacement radiator, which is presumably an R33 radiator also. The problem is, the replacement is a lot taller than the original, and the bonnet wont close due to the height, so i dont know which each radiator is from.
So im trying to work out which radiator is which. Ive attached three pics, first the original radiator, then both, then the replacement. If anyone can shed the light on which is which thatd be good.
Thanks
https://www.sau.com.au/forums/topic/49409-which-radiator-is-which/
is the left one r32 and right one r33? would an r33 radiator fit in an r32? cause ive just spent money buying the right side one, so possibly could trade it for an r32 radiator? r33 ones are worth more arent they?
ive just spoken to the guy who supplied the radiator, he said the guys who did his conversion swapped the r33 radiator from halfcut with an r32 without telling him, so thats why he thought the r33 radiator would fit.
height from lip->lip of the core on the left one is about 38cm, and lip->lip on the right hand side one was 40cm. in addition, the top tank is another 1cm or so taller on the right one.
thickness and width are the same for both, and id assume at least one of probably both are from either r32/r33, so i guess whatever standard size they are, though i could measure this if it helps.
noticable differences on the top tank is that the large radiator has a lopsided top, with the hose side being taller than non hose side, whereas on the smaller radiator is reasonably symmetrical
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
