Just wondering if anyone can show me some pics of people install subs in an R33 GTS-T with space saving in mind...i will need all the space i can get...looking at 2x10' subs maybe 12's if the fit...but basically i want the most boot space...i'm bass crazy but need the space. listen to hip-hop so bass is important jsut wondering if anyone has/knows of any really good space saver ideas...thanks guys
https://www.sau.com.au/forums/topic/49450-space-saver-sub-installs/
got no pics, but for a decent amount of bass my mate has 1 10" audiobahn sub (not sure what model) and a fusion powerplant amp (300rms) going into it...it pumps!! thats honestly all you really need unless going for something special...
my pioneer tsw305c (12") off my boss ba-1000 amp doesnt go that bad aye...it gets to the point where it sounds like your talking into a fan, hehe.
thanks for the help guys...so u think i can make a good install without taking up ANY boot space...? i want heaps of bass so i figured 2x 10" would work beta but i'm sort of a newb so not to sure...thanks for the help again n if anyone has pics of an install taking up none or very little space please post it
In theory if you wanted to relocate your little computer box and the battery maybe to the rear quarter panel (not sure if theres room there but last time i looked in a r33 there might be) perhaps you could put your subs (if they were matched correctly for optimal space in the sub for that volume) behind the seats but not past the wheels arches.
Otherwise I think if you rip out your boot you might be able to go custom fibre or something in your rear quarters? I know r32 can have this I'm not sure bout r33s.
I'm just finishing off the final touches of mine. While I've lost about 5'' in the depth of the boot, i've got way more space than i ever did with a sub box and 3 amps.
Its a bugger to get to the space saver, but i figure its worth it, and i still have access to everything. Getting great bass at the moment with just one 12'' and there's plenty of room left over.
I'll have some progressive pics up next week
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
