IS HERE!
Just got the call from Gareth that the car has been dropped off :)
Front bar is in the car... im guessing it was too low to move around withit on.
Im just waiting for my camera to charge and my cousin to get outta bed and WHERE OFF! :(
https://www.sau.com.au/forums/topic/49465-the-beast/
  • Replies 73
it was dropped off at his place by truck...
im going to pick it up and store it here until i can comply it... while its here i'll do all the fluids and easy stuff.
hopefully the rds dry up by the time i get there and it doesnt rain more.
https://www.sau.com.au/forums/topic/49465-the-beast/#findComment-987400
as long as you don't have lead foot-itis then u got nothing to worry about...
my ceffy had tiny tiny wheels so it was dori dori all the way from the docks... you've got GTR style rims so turakushon shouldn't be a problem.
https://www.sau.com.au/forums/topic/49465-the-beast/#findComment-987407
havent taken many pics cause it needs a cleaning :P
took this tho... its only being reved to 4000 but u kinda get the idea... http://home.iprimus.com.au/fairy_princess/MVI_0003.AVI
i drove it home from gareths in glen waverly and oh boy was that fun... scared the begeesus out of people on the side of road and the people with the windows down :(
heres a few pics... check out the size of the bloody oil cooler ;)
http://www.superhonda.com/photopost/showga...00&ppuser=69108
the funniest thing about it is the paint on the engine bay :rant: its glitterised
https://www.sau.com.au/forums/topic/49465-the-beast/#findComment-988100
the LSD is pretty mental... not used to driving a car with such a mental LSD.
even turning corners at 15kmh u can hear it trying to spin the wheels... its weird.
my cousin was pissing himself laughing at the looks from people when i started to boot it :P
https://www.sau.com.au/forums/topic/49465-the-beast/#findComment-988125
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
