Sounds like you guys had a great time out there, and well done for coming top of the class :P
Now....I'll be down there from Monday until end of October, so I expect you all to
1) Organise a track day at each Vic track before then
2) Let me know where I can hire a cheap mx5/mrs/mgf etc etc
  • Replies 218
Adz,
You have done very well mate, congrats.
I was following you for a while and you were driving pretty smooth.
Ferni,
To answer your question from the other thread, my oil temp was 100 degrees. Do not worry too much about the guides around the cooler core, but get some vents happenning in your guard lining to circulate the air.
Chris were having highish oil temps as well and he drilled some holes on the lining as a temporary fix. I forgot to ask him how much of a difference it made, but he will let us know when he signs in.
My corner speeds were comparatively lower than everyone else, which fully explains the slower lap times. It was probably the mixture of driver and rubber and there is a lot improve on both counts.
Snwoman,
That is one hot pic, but Geoff is definitely sucking it in. :P
Cheers mate, you were pretty good for street tyres too. Did you like my drift style show on corner 5? Didn't expect to see you facing towards me when I came round on the next lap! Thats what you get for trying to keep up with a GT-40 on slicks! :P Mind you later on Semi's I had a moment, managed to floor it and bring it round though.
Did you mean turn 6...? Not much of a drift action was happenning, you were mostly spinning them on a straight line. A lot of smoke though, the girls thought someone blew up. :D
You were too slow anyway, so i took you over. :D
Snowman,
You are soft and sexy and smell tough with a whiff of petrol scent. :bahaha:
Chris told me that his temps dropped from about 120 on sat to about 110 on sun with the holes in the wheel guard inner, and he was driving harder on the sun.
Bingo Andrew, there is the next mod you have to perform before the next track day.
If you are eager enough, you can manufacture some sort of a guide around the core as well. Here is what my HKS one look like :
It's in two pieces and bolted together.
ahhh i didn't realise there were 2 peices, i was just thinking it was the left (inside) peice... shouldn't be to hard to measure up and get made, but first i would like to do what you have done with the gtst guard inner
...and there she sat all day, all dressed up and no date :(
The boys discuss the Wallabies disappointing Sat night performance :(
I was happy to throw the tyres on everyones cars, as the only thing i could really salvage from the weekend was seeing the big smiles of others as they jumped out of their cars :) ...its the only thing that kept me going. Does Geoff ever stop smiling :D
Forget lap times and sticky rubber, who didnt have an off? You should be ashamed :flamed: If you dont spin you aint try'n :D ...
Had a couple of big moments in the wet with the tail wagging the dog, but I caught them...kinda. No offs or full spins. I'm smiling just thinking about it :)
The ability of the track rubber allows so much more confidence and suddenly the race cars were not pulling anything in the turns, so were slaughtered on the straights.
Talked to the guy with the GT Falcon after the event and he'd had a good day too but was a bit put out by getting done by skylines. Quote "And how would sir like his ass handed to him today"
Troy - check out the photo of Andrew, Geoff and Emre (posted above) - i dont see much of a smile there - although it must be the only minute of the whole weekend that he wasn't smiling.
What can we say - Geoff is just a happy guy
...and more.
Emre - thanks for the info on the oil cooler. Was at least 10-15 degrees cooler with those holes I made.
Andrew - i'm going to have to sabotage your car if I cant beat you soon....
Troy - get your biatch back on the road. I wanna see that Geoff style grin light up on your face.
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
