Hi Guys
I am having some trouble with my r33 on low boost the car is hitting the standard boost but when it comes to highter revs the boost creaps to a 1bar.
and on high boost it runs a little less than a bar but realy doesn't seem to have a much more power than standard boost!
I have a HKS boost controller, I turned off the unit and the car still did the same thing on low boost (crept to a bar). As I thought when the unit is off it will go back to standard boost.
what could be wrong?
https://www.sau.com.au/forums/topic/49511-~low-boost-creap-to-1bar~/
Have you removed the standard boost controller/solenoid?
What it does, at standard boost, is hold 5psi till around 5000rpm then goes to 7psi
So if youre using a boost controller with all the factory boost controlling stuff still in place, then it will mimick the above.
You should get a oil catch can if boosting over 10psi, the older the engine the more blowby, eventually making oil get through everything
    • It's the same with many brands that find their way into promotion via Youtube channel sponsorships. Those stainless guys, e-mail cut shippit, various other service and product companies.... they try to make it so that the only name that comes to mind when you think of doing those things is them, and then you just go get their stuff because your favourite channels are using it, so it must be good AND good value. Notwithstanding that the YT'ers don't pay anything for it. But a lot of people are not that sophisticated.
    • Yeh vibrant looks a bit overpriced, but thats the US market in general, they pay $50k for a gtst...
    • It's surprising you say this because talking to someone who headed Toyota's CARB certification efforts and was now working for Mercedes doing similar things he said he never had a case where he found that it was necessary to reduce ignition timing for that reason. Knock limits yes, but never because of in-cylinder emissions profile. I'm guessing between EGR and the number of TWCs modern cars stack in series it's not really a problem. I really doubt the NEO is that big a difference. You get what, EV6 injectors, coil on plug, a cold start valve that works off coolant temp instead of basically fixed time constant valve, and... I really can't think of anything else. Not like Toyota where they shipped first gen GDI in the 2JZ-FSE.  Something I didn't realize is that Japan didn't revise their emissions standards for light duty passenger cars between 1978 and 2000. I'm guessing there's a bit of phase-in, but that explains why 2002 killed a bunch of JDM sports cars off all at once. FD3S, A80, S15, Z32, R34, Z15A GTO all died off for that reason. And explains how all these cars got away with no EGR or much of anything other than a TWC and charcoal canister for the longest time.
    • 100% agree. Best bet on an RB will be NEO, but even it will be a long way off. Emissions is one of the big reasons car manufacturers went to DBW and constantly variable cams. When cruising, open the throttle right up, but reduce dynamic compression so low, that it's basically an unrestricted air pump moving very little air.
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
