I've just recently got a bigger turbo install'd, and the car keeps STALLING even if i dont hit boost. The cars pretty much standard except for the turbo now, am i missing something?.. an aftermarket ecu? being that my car is automatic makes me kinda feel reluctant to get one.
Or could there be another option to it?
oh and another thing, is there any way of making the turbo spool up any earlier than 3500rpm?
https://www.sau.com.au/forums/topic/49517-stalling-automatic/
woah a number of issues you have there
to answer your first question (ie why is it stalling) i would say check for an air leak in the cooler pipes
but you say your car is standard apart from the bigger turbo... i ask why? if you don't have exhaust/filter/cooler/fuelpump/ecu then why are you goign the turbo route? you may find that it gives you no more power with that shitty intercooler and stock exhaust...
good luck anyway.
Waz.
Time to adjust the idle bypass, increase the idle 100 rpm or so, add a bit more air and the ecu will add fuel to compensate. The result is a stronger idle. You may also be able to sneak a bit more ignition advance via the CAS, that strengthens up the idle as well.
The bottom line is you really need some ECU tuning, my rule of thumb is change turbo = change ECU. If you only want say around 220 rwkw, and being an auto, an SAFC may be enough to do the job to your satisfaction. If you power asperations are higher then a full ECU is the go. There are plenty of threads on ECU's in auto's, I strongly suggest you do a search and read session.
Hope that helps
Hope that helps
Hi SydneyKid, You seem to know alot when it comes to these things i pressume.
I was told about adjusting the idle but the car idles fine, bout 800rpm. But when i free rev it, its drops down low enough to stall. Same goes with driving.
A few q's.
If it was the airflow meter, would it be idleing rough? But it aiint, so it couldnt be?
I dont have a hi`flow cat. problem?
and one last thing, i noticed there's a hose bout 1" in diameter coming from the top of the engine bay that is not connect'd to anything, just sitting there unblocked. no idea where it goes or where it came from. Attached is a pic of wat hose im talkin bout.
Thanx for your time
Hope that helps
A few q's.
Thanx for your time
why are u reluctant to get a aftermarket ecu? it'll save u so much hassles in terms of tuning out problems like this. plenty of others have done this b4 .....why not do the same
it would b my first expenditure if i had that sort of mods done.
go the dip on a ecu m8
MT
i think thats your problem right there.. any pressure leak results in stalling and other stupid crap.. block it off properly at both ends (where its supposed to go also).. or connect it back up tomorrow and your problem should go away.
Hey I have the same problem and my car is also an automatic
I had a little mishap awhile back and had to replace my exhaust cam with HKS 256
It ran ok for awhile but the idle started to get rougher and rougher
now it stalls sometimes at the lights and if I free rev it, it would stall
Cold starts are horrible have to pump some gas and the engine takes awhile to start (can hear this strange clicking noise as well)
sometimes when Im driving and I let go of the throttle, the engine would start struggling (can hear popping in the exhaust)
My mechanic seems to think there's something wrong with the timing, something about the CAS sending the wrong info to the ECU. But it seems ok at higher revs or when the car is allready rolling
Is this just because standard ECU cant take 256 ex cam? or is the CAS screwed? or maybe the cam wasnt installed correctly?
A few q's.
Thanx for your time
I bet thats your problem, when putting my catch can on, if these arent connected the engine hunts for idle all over the place, mine didnt stall, but it did make the idle go nuts.
btw- im changing my turbo soon on an auto aswell, i just got safc2 and sitc ages back, will do what i need nicely and lots cheaper.
Thanks for ur help guys, but i fink its the afm. i ran a diagnostic checkup and it read out a problem with the MASS AIR FOLW SENSOR.
im gonna try out my friends afm and hopefully it will solve my problems.,..
cheers.
ill get back later and tell u guys the result
my friend works at a nissan dealer shop and yeh he had the diagnostic remote computer. pretty funky item knowing that it costs more then wot my car is worth.
my afm sticker is pink. so does that mean i have to use a s2 r33 afm? or will a s1 green sticker still work?
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
