Hey guys, I've posted this before, and have checked most things I know how too. Anyhow, my problem is than when taking off, on gear changes when accelerating, and when reversing, I usually get a loud "click" noise from my rear right wheel. If I take off very gently it doesn't happen. I have checked my rear suspension and nothing seems loose. Is it hard to get into the rear hubs and check the handbrake setup? Any ideas anyone? It's been happening for a few months now and seems to be getting worse. Any thoughts appreciated!!
https://www.sau.com.au/forums/topic/49522-still-got-loud-click-pls-help/
I have not seen this problem on a skyline, but I did have a similar problem on another car. It turned out to be a universal joint although initially I couldn’t find any free play when checking it. The cause was obvious when it broke and the tail shaft shook lose and hit the ground (at 80kmph) fortunately it was the rear universal.
My car makes alot of clicking noises from the rear when taking off or reversing. It usually sounds like the right rear cause it's closer to you then the left and you may find it is both sides or even central as in the diff.
If it's more of a clunck then I would have a good look at the four rear subframe mounts. I broke two on mine and the whole rear of the car walked around and under some circumstances would clunk and bang when going over lumps and bumps in the road.
If it is the diff you should here more of a ratchet sound of a few clicks rather than one single.
Good Luck
Well, checked all the bolts etc- all tight. Did notice that while jacked up with the handbrake on, the wheel has play in it. Not heaps, but it will turn back and forth a few centimeters. Dunno, might have to fork out cash to have someone look at it, as much as I hate to spend money.
I have had this same problem and believe me it has sent me nuts in trying to work it out. After speaking to a number of mechanics I was told that it is simply my rear brakes pads not sitting in the caliper properly. Usually happens with after market pads.
The best solution I found if using the existing brakes is to remove and clean your pads and any gunk around the piston area and before refitting them place some disc brake pad adhesive (known as Disc brake quiet from Repco) on the backing plate of the pad and piston area. This will dry and keep the pad from moving around.
Alternatively you could always fit some genuine pads and that will solve the problem.
At the end of the day its not a serious problem but very annoying.
Cheers plaganis. Took it for an alignment recently and the mechanic said he couldn't find anything wrong. Good news I guess, but the noise is still annoying!!
LOL...this is trajic. Noone in this country knows what causes the noise. Ive looked under my car. Ive had several reputable, well versed with imports, places look at the noise. Noone can suss it out, they tell me everything is A-OK, just to live with the noise...but it Sh1ts me to death.
Ill buy a case of beer to anyone that can suss this prob, mine is a clicking noise from what sounds liek the right rear, loud ratchet noise is a good way to explain it
the back and forth play in the wheel is normal...forget it.....as for the click forwards and gears and the ratchet in reverse.......i say check you uni joints on the tailshaft......but my gut feeling is that your wheel bearing has ben tightened to much and crushed the bearings out of round.......can you feel any roughness when turning the wheel while jacked up?
i have had this before......coan someone record the sound? that would make diagnosis much easier. :P
It could be a CV joint in the RH half-shaft. Try swapping it to LH side, and see if the noise follows. Check them while you have them out.
isnt the right half shaft shorter than the left? i cant recall
the shafts have to be the same length. the diff is in the middle/
to anyone with rear noises: Does the noise go away when u apply the brakes?
uni joints or diff pinion backlash (freeplay): would make a clunck noise under normal & hard accel. and quick de-accel.
Grinding noise: worn out or dry tail shaft centre bearing.
has anyone jacked up the rear of the car driven it in gear until it made the noise and have someone underneath the car trying to locate where the noise is coming from.
yes the diff is in the middle but the crown wheel is off to one side of the pinion, think about it for a second and you'll see what i mean...it would only be a few millimeters.......I'd check them both against each other before swapping them....because they WILL fit but damage can and most likely will be done when the car is driven as it will place massive pressure on the lsd/spidergears.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
