My Car
*1993 Gun metal grey R32 GTS-T (series 2)
* Sun Roof
* 5 Speed Manual
* Power Windows
* Climate Control
* Central Locking
* Alarm With Keyless Entry
* Electric Mirrors
Mods:
* Low Kms RB20DET Motor (28,007kms On Purchase)
* VG30 Roller Bearing Turbo (Currently has the stock T3 turbo Fitted)
* Locked LSD
* Ceramic Single Plate Button Clutch With Sprung Centre
* Turbo Smart Bleed Valve
* Blitz FATT Turbo Timer
* Apexi RSM Rev/Speed Meter (Blue Screen)
* Auto Meter 20PSI Boost Guage With Chrome Cup
* Ital Steering Wheel
* Pod Filter
* 3" Exhaust System
* 16" 6 Spoke Aloy Wheels (Buddy Club P1 Look Alikes)
* Tinted Windows
selling my car as im after a Supra, WRX or some form of BMW coupe. if anyone has any of those id be interested in a swap.
$15,500
Cheersl.
karim.
https://www.sau.com.au/forums/topic/49530-1993-r32-gts-t-adelaide/
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
