ever since putting on my FMIC and EBC whenever i run more than stock boost when i'm excelerating my car makes a flutter sound from the turbo side of the motor, i pulled my stock bov to check it but it seems fine, the cooler pipes are tight but i have not check the turbo outlet pipe cause i'll have to pull the other pipes off to get to it.
what else could it be, the more load the car is under the worse the flutter.
https://www.sau.com.au/forums/topic/49551-help-fludder-sound/
not sure, but lucky its just a flutter :D
when i put my fmic in it seems to have maxed my ecu. i get a flat spot between 4500-5500 now. i'm gonna have to buy a new ecu (powerfc) or get a piggyback to fix it. much more expensive than i thought it would be :*(
lindsey34 - from what you say, it sounds like this happens when you are accelerating rather than while changing gears.. is this correct?
if so, sounds like a surge issue. I'm not too sure on a resolution. first time I have heard this happen on a stock turbo.
Jaff - all you might need to do is change the spark plugs and gap the new plugs to 0.8mm. go buy some $4 each plugs (ngk copper ones) and make sure the gap is 0.8mm. that should fix your flat spot.
still doing it the more boost the worse it is.
i'm sick of driving with stock boost might call ice and see what they think.
do you think it could possibly be the wastgate causing the problem.
you know when you excelerate how the pod makes the shhhhhhhhhhhh sound well when mine is boosted it sounds like shh, shh, shh, shh, shh, shh, shh, shh ? my brothers car has exact same mods but doesn't do it.
no the gasket is fine.
and I still highly doubt it's the bov.
what boost does this start happening at?
like at stock it's fine.. does it do it at 9psi? or 10psi?
play around with your boost controller.
start at stock and then increase by 1psi untill it starts happening..
and when it does happen, what does your boost gauge do? does it keep rising steady or does it move around when you hear sh sh sh sh sh ???
you are using an after market boost gauge right? not working off the stock gtst one i hope..
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
