NISSAN R33 PARTS
Stock Shocks (GC) = Make an Offer
Apexi lowered Heavy duty Springs = Make an Offer
Stock Steering wheel (series1) = Make an Offer
Cat back exhaust (not stock) = Make an Offer
Stock rear spoiler (series1+2) = Make an Offer
FrontMountIntercooler Kit w/polished piping (600x300x75 Core)(BrandNew) = $1000.00
Stock front guard indicators = Make an Offer
Nismo Clear Side indicators (R33) = $100.00
Stealth rear wing (Flat spoiler)(BrandNew) = $300 Deliveried
1 x Passenger side indicator/fog light = Make an Offer
Stock Gear Knob = Make an Offer
Stock Cooler = Make an Offer
GTR Nismo Stainless Carbon Fibre Muffler 3" Full Exhaust System = Make an Offer
GTR Tein NR Suspension = Make an Offer
WHEELS
Set of 15" wheels with VG tyres (Good for drifting)(4/114) = $100.00
17" Sparco 6 Spoke rims with brand new tyres(215=Front)(225=Rear)(4/114) = $800.00
15” Nissan S13 SR rims and tyres (Good tyres)(4/114) = Make an Offer
UNIVERSAL PARTS
Pair of Recaro reclinable seats(Brand New)(With universal rails) = $800.00
Sony CD player (Like new)= $150.00
CA18DET AFM (GC) = $75.00
CA18DET Stock ECU = $100.00
Line Locker Kit (Brand New)(Inbox) = $200.00
TurboSmart "BOOST TEE" Manual boost controller = Make An Offer
Also will trade/swap for:
- Coilovers (GTST)(Height and damper)
- R33 Eye lids
- turbo timer
- Boost Controller
https://www.sau.com.au/forums/topic/49552-garagecleanup/
  • 4 weeks later...
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
