I need some advice on the following. Car is an R33 GTS-25t.
1. I have been told I need to replace my diff oil. What do you all use and recommend? Also, what exactly is a diff? Where in the car is it? How do you change it? Etc, etc.
2. I need to top up my power steering fluid as it has been leaking. Again, what do you all use and recommend?
https://www.sau.com.au/forums/topic/49586-what-do-i-use/
For the diff, use a Castrol or Penrite 80w/90 (or similar) Gear Oil. Ask your local Autobarn or Repco. Frankly, filling the diff is a pig of a job unless you have some sort of gun. Better on the nerves to pay someone to do it for you.
Steering - Auto Trans fluid does the trick.
https://www.sau.com.au/forums/topic/49586-what-do-i-use/#findComment-990464
