  Silent said:
Ta da! my custom dash
Note now its only single din :nyaanyaa:
nice. that looks shiny.. now ive done it my self i know how much work goes into it :laugh:
howd you cover the the gap were the stock cd deck was? nice
  • Replies 58
  foamer_69 said:
how do you get that centre console out? i had a try on my car. undid the screw behind the ashtray, but i still couldn't get it out. felt like i was going to snap something if i pulled too hard.
the console going over all your buttons and vents?.. you need to pull it from left side and start uncliping it. its cliped on there :nyaanyaa:.. once you get it off, its easy from there. then you need to unplug everything from the back before you can take it completly off..
  • 1 month later...
  • 11 months later...
  2BNVS said:
this is my mates r32, although done by an interior place, it is bloody nice and top quality...so there are a few shmick jobs goin around thats for sure
ben...
That looks hot dude! You know where and how much it cost him?
Silent, how did you convert it 2 single din? Was looking at doing the same thing with my change holden in the centre console. Those interiors look really cool. I was going to paint my plastics red, and trim my seats, door trims, boots, roof, and most other things in the same colour red leather. Need alot more money tho. see how we go. Sort of there, with my SNAP-ON seat cover
  Let Me Drive said:
hay i have my r33 dune in vibrant blue and it looks great get loads of complements and it makes my car interior just look great.
i have not posted them but if you want i can send them to u by email so if i could grab you email or ever pm it ill send them to you
can i please get a copy of them PMed to me please thinking of blue in mine but cant choose what exact blue thanx
cheers
Dan
cheers
Dan
Hey there budy i did mine bout a year ago and looks sick, Did it in electric blue
I went into auto barn and looked on their brake caliper paint i think its KHM or something similar to that it turns out a treat the paint sets hard as and it wont chip crack or peal of, The down side to this paint is once you have done it let it harden under a heat light for a few hours in a well ventilated area as it puts of very harsh vapours after that it will almost never chip or peal looks trick in the sun once armouraled
  • 9 months later...
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
