Hi I have numerous parts for sale they include:
R33 GTR
Standard Sideskirts $230
Standard Mirrors $150
Standard Side Indicators $30
Standard Dash Instruments (34,803klms) $330
Standard Piping $150
Standard Fuel Rail $20
Standard Turbo's ( 1 missing rear wheel, no shaft play) $600
Standard Oil Pump $120
Standard Oil Baffle $50
Standard Dumps $100
Standard Cam Gears $30
Standard Cam Cover $100
Standard Ignition Coils $220
Standard Shifter $45
I ALSO HAVE OTHER MISCELLANEOUS PARTS:
Carbon Fibre 3D GT Wing $750
Nismo Stainless Carbon Fibre Muffler 3" Cat Back Exhaust System $600
King "Super Low" Springs $80
Nismo Rear Suspension $130
Blitz "BIG" Boost Gauge $150
Blitz Exhaust Temp Gauge $170
Blitz Water Temp Gauge $160
3" Catalytic Convertor $120
4" Catalytic Convertor $130
Pierburg 400Hp+ External Fuel PumpsX2 $90 each
HKS (Green) Twin Pod Air Filters $120
Momo Corse Steering Wheel with Boss Kit $200
Splitfire Ignition Coils RB $465
HKS Fuel Rail for GTR with fittings $285
HKS Oil Cooler GTR $635
3" Straight through cat pipe looks like cat but straight pipe $100
Power FC Hand Controller $290
Pioneer P6550 In dash DVD Player (Touch Screen Like NEW) $2250
Clarion 12" Subwoofer in Box $150
Small Amplifier to drive Sub $75
SMS ME ON 0400200179
https://www.sau.com.au/forums/topic/49636-gtr-parts-and-others/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
