i was looking at some older threads and found one that said that you can use a bleed valve on your standard fuel reg to adjust pressure? how does this work and would you need to use a fuel pressure gauge to set it?
Thanks guys
Mr_GTS4
https://www.sau.com.au/forums/topic/49655-bleed-valve-on-fuel-reg-how/
Never heard of such a thing ever.But it's a good budget idea none the less.
But no it will not work unless you plan on internally modifying the flange of the fpr for adjustment.To hard for someone with limited access to the proper tools.Ive found one that someone has allready done through a search on the net and wherther it works or not is another question as i havent read any of it.
Heres a home made jobbie right here
I say spend the money on a cheapie that you know is going to work you dont need to go for the brand names,you know wot i mean or you will after youo see what they look like in the end.
Thanks guys
Mr_GTS4
OK I give up, why would you want to lower the fuel pressure? Because if you put a bleed valve in between the FPR and the plenum that's what would happen. Surely you want to raise the pressure, or have I missed something? :confused:
But if you put a bleed on the manifold pressure line, then you could successsfully raise the fuel pressure.
There was an article in Zoom (?, might have been Autospeed) some time ago about just such a device, manufactured by one of the performance shops in Adelaide.
I remember reading an article in a magazine a fair while ago that one workshop found a cheapish way to lower the a/f ratio's by controling (to a degree !!) the fuel presure while on boost.
I don't fully understand how it worked, but I presume it bled off some presure etc..
Actually, I think someone here on SAU had one installed for a while.
A bit of a dodgy way if you ask me, I'd save myself the risk and get a S-AFC instead.
J
I have heard of reducing the fuel pressure to lean off an engine that is running too rich. Usually with an adjustable fuel pressure regulator, but I guess you could do it with a cheap bleed valve. In fact you could probably connect an electronic boost controller in between the plenum and the fuel pressure regulator and move the fuel pressure around to over come any rich spots. You can't do that for lean spots thoughs.
So, I am confused, where does the extra pressure (it's really boost ) come from? :headspin:
help us we need help.. hahahha
yeha i don't know, but maybe they thought that because a bleed valve makes boost higher, we could use it on a FPR and increase fuel pressure... HAHAHAHAHA thats funny.
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end a made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
    • As someone who has pineapples, and horrible axle tramp... should I change these to collars? Is that what you're saying here? Why did you choose these instead of getting pineapples where you said you had good experiences of? I'd love to even attempt to get rid of axle tramp, I either get complete bogginess or absolute insane wheelspin, anything even remotely in between results in filling-removal axle tramp, to the point where launching the car is just not something I do.
    • Lucky for that, because putting ethanol in fuel only lowers the bulk cost of fuel if it's in 91 Add it to 98, 85% of it even and it quintuples in price. Strange physics. f**k you United, Gouging c***ts.
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
