  DJ_L3ThAL said:
u got an aftermnarket comp ? coz wolf 3ds take ages to crank ive noticed as part of them, nothing wrong with that, and i *think* my powerfc made mine take 1 or 2 cranks longer, meh, it still starts n purrs perfectly ;)
shivam - how much would all dat cost lol ? i mean what would say ice do for a 100k'er' ? anyone know ? i gotta head down there soon anyways to have a chat once my brakes are on the car (tomorrow YAY!) so if noone knows i guess ill enquire down there as the car is at alost 95,000 now which is when i wanna get it done
:cheers:
Yes well all aftermarket comps should not result in the car not starting first time i think it has a lot to do with who installed and tuned it..
Never had any problems with wolf firing first or second crank i guess some people don't put in the extra effort when installnig and setting up aftermarket ecu's.
On that not who cares if it takes 1 or 2 cranks its not a problem just a feature as paul said :D
  • Replies 40
nah its the stock ecu that came with the car. if i give the car power first, let acc come on for a few seconds then crank it, it seems to start straight away its only when i turn to full crank from no power it doesnt start.
also if and when the car doesnt start first crank the apexi timer lights up with the a/f ratio. normally the apexi timer shows --- for the a/f ratio. go figure
  deorbit said:
i'm pretty sure the UAS site still has this information listed but just in case it doesn't.
  Major Service Items List
· Systems Check and reset memory and check all sensors and check for any fault codes.
· Systems cleaner, pressurized can with long bendy hose inserted in various locations to clean carbon
build up in plenum chamber and tops of valves and ports as well as PCV and throttle body. (s)
· On line injection clean.
· New Iridium Spark Plugs.
· Water Pump.
· Thermostat
· Cam belt
· Drive belts.
· Oil Filter
· Fuel Filter For 300ZX new hoses either side of water pump.
· Check cam and crank seals for leaks usually OK and extra if seals required $14 each. Cranks Seal $25 Extra labour one to two hours.
· Check cam belt guide and tensioner pullies (extra $150 each for 300ZX other cars can be more) if required .
· All electricals, exhaust, suspension. Coolant and intake hoses.
· Gear oil 75w- 90 or auto trans service.
· Engine, gearbox and power steering get Uniglide treatment.
· Clutch and brake fluid flushed and bleed.
· Radiator and engine flush.
· Clean and treat battery terminals.
· Clean terminals to injector plugs, ignition coils.
· Compression test.
· Spray lubricant on throttle linkages and other.
· Adjust water sprayers and additive used
· Lubricate door hinges and strikers, bonnet latch, boot hinges, aerial mast.
· Check and tighten sub frame and suspension and cross member bolts etc.
· Tyre pressures checked and corrected.
· Air filter replaced or if performance filters cleaned and re oiled.
· Check list for our technicians and report given.
· Full day required (8am drop off).
Optional extras
· Steam clean engine bay $30
· Adjustable Cam Sprockets see parts section for options.
· 300ZX and Skylines silicone radiator hoses, or 300ZX optional stainless lower radiator hose.
Is there anywhere in Melbourne that can do a service like this? Nissan FTG? Whenever I go to Ice for a service they just say "what would you like done?"
And I say whatever you think, i dont know, and they just do the oil, filter and maybe the plugs. I mean Ice are good, but i cant see them lubricating my door hinges and tightning my suspension and subframe.
  • 1 year later...
Sorry to dig up an old thread... but I have my 100k service and I want to do it proper.
Can you or anyone suggest how much of this would need to be done by a professional, and how much could be done by a noob? And by noob I mean I have changed my oil and oil filter once.
· Water Pump.
· Thermostat
· Cam belt
· Drive belts.
· Oil Filter
· Compression test.
Optional extras
do u know any mechanics that can help u with it should u mess things up? u'll need to get a diagnositc for the electrical side of it, and be able to use one (ie leave it to a pro). things like timing belt and water pump etc u might eb able to do, just read up on it first, do alot of research. and u will need lots of good tools, do u have all the right tools? torque rench/compression tester etc. u done anything like findint TDC and lining up timing marks?
My mechanic is very sick at the moment and won't be able to help for a while. I've been meaning to ask him who I should use in the mean time. My dad used to be really into cars... but that was pre-injection/computers etc so don't know how much he will be able to help.
I should have mentioned the timing belt has already been done, but not the idler or pulley bearings (note I have no idea what these are). That's the only reason I'd need to find TDC right, to do the timing belt?
I have access to a lot of tools (my dad is a toolmaker) and should have use of a hoist shortly. Not sure about compression testing.
I don't mind getting all the tricky stuff done by someone, but I just want to learn a thing or two and save some money. Speaking of which, should I try to get most of the parts myself and supply to the mechanic? E.g. those bearings which I know nothing of are hundreds of dollars for authentic Nissan ones, or under a hundred for NSK equivalent (thread).
What would you suggest for doing research - just reading the forums/net? Or maybe there is a book/manual I could get that would be helpful?
Thanks!
you should probably get these changed.. or checked if possible to make sure there alrite.
I had my timing belt done and didnt get the idle bearing/pulley thingies changed... (as my mechanic never mentioned it or found it important enough to change...) and 2 days later they snapped and belt came off.... had to rebuild engine :D
Yes, make sure you the idler bearings, just as important as the belt. I helped a friend do a service the other week. Pretty big job as far as time go's. From memory was around $600 in parts and that was trade!
A lot of the things there are a bit wanky, we were VERY particular with this car and did everything that NEEDED to be done.
We didn't have any super special tools, the harmonic balancer has marks to line everything up.
-Diff oil
-Gearbox oil
-Engine oil
-Oil filter
-Fuel filter
-Idler bearings
-Cam belt
-Spark plugs
-Water and coolent
-Water pump (why not while you are there)
-Cam and crank seals
-Cleaned air filter
