After the SAU Dyno Day at UAS, I noticed that boost was all over the place using the Autospeed boost controller.
Boost was bleeding off up top, but this is to be expected from a pneumatic boost control system.
I decided to see if I could get the curve to sit a bit flatter than what it was. After sourcing a wastegate actuator from an R32 GTS-T, which is, I believe spring rated to 10 PSI and is a direct fit we ran the car back on the Dyno to compare the difference.
Boost was sitting pretty flat though the Rev range but the dreaded bleed off was still present. I have plotted the result on a XLS spread sheet and created this chart. Hope this helps anyone who is thinking of performing this cheap and easy mode.
The part was picked up from SSS performance for $30 and was about 15-20 min to fit. I did have to reset the boost controller after the fit as boost was hitting 20 PSI with the original setting for the R33 wastegate actuator.
Sam
Yellow is the R32 actuator
Red = R33
https://www.sau.com.au/forums/topic/49726-boost-curve/
Guest Robo's
That's a terrific little exercise. Although it comes to suspicion that you may had problems with your R33 Actuator. I have got similiar graph to your R32 actuator with the stock actuator with no dips, but it may fall of more sharply than the R32 actuator.
Ive installed the HKS actuator and to tell the truth it drops at high revs too. Whether it drops off the same as the R33 one, i dont know. Its going on the dyno next week too see if we can pick up any boost up high but i think it might be marginal.
https://www.sau.com.au/forums/topic/49726-boost-curve/#findComment-991643
The old actuator was ok just the boost settings may have been a little different. The drop off is less with the R32. Bleeding off up top is common with bleed valves, may have to do with heat, restriction or something along that line. I think SK had a post about why it bleeds. In any case I am trying to source a APEXi boost control kit for the PFC.
Keep us posted with your results Rob
Chers
https://www.sau.com.au/forums/topic/49726-boost-curve/#findComment-991760
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end are made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
