  • Replies 61
if you guys thought that was wierd, I'll post up a pic of the Cefvia in a couple of hours...
also I got a few pics of a wierd Onevia station wagon conversion and a widebody ceffy kit (which is for sale).
I wanna c the pics too man.... (especially the wide-body ceffie kit...)
lol yeah i had another look and second guessed it :P then realised it was just the guards made it look funny :)
cant believe they actually are LHD? didnt know they were shipped anywhere as a low volume import in LHD? unless they did it custom.
Yeah, i wouldn't have a clue about that either... most likely a custom job though i'd say... I wanted to do a S15 front on my 32 GTS-t but then i just bought the GTR lol! (but now that's for sale a ceffies in sights :P) either way, no 180sx front ends for me lol!
Ok, the Yankys got s13s rite? In both 180sx format, and silvia. So put two and two together. WAY too much money to get a skyline over there, and converted (look at fatf, skyline in that rhd...) So, my guess would be 180 front, etc, skyline rear as thats not different for either hand drive. Then they just change a few more pannels, and walla!
Either that or full 180sx, with the R32 pannels, with a fair bit of effort it would be doable.
    • That's f**ked up. I'd guess it's more likely that you have an entire S13 subframe in there. Does it still have HICAS mounting points? Seeing as it is quite possible that yours is the only such converted car in the world, you'll probably struggle to find someone who can tell you from direct experience. 'Twere I you, I'd be looking for 4 stud Skyline rear brakes and convert back. At a minimum. Preferably go find all the stuff you need to put it back to 5 stud (assuming you're happy to change wheels) and upgrade to some decent brakes. You don't even need much stock stuff. Don't need calipers or rotors, as you can go fully aftermarket. Just needs hubs and the other bits and bobs that are different to what you have now.
    • The engine has nothing to do with it. The physical space behind the headlight is the limiting factor. And the height. The height of the NS70 is the same as stock. So the clamp bar across the top goes on nice. The battery tray is big enough for it to sit on. The X is for extra capacity - it has even more lead in it than the non-X NS70. Heavy f**ker. But it's not a track car, so I will suffer a couple of extra kg. In the case of the R34, maybe the physical space there is not as deep (forward-backward, not up down). Hence why they say the 60 is the biggest. But I would never trust a catalogue to tell me what will fit. I have the car. I have the existing battery. I have the tape measure. I have the dimensions of all the available batteries. I find the biggest box that will go in. (With the right terminals in the right places, of course).
    • Hello! I have been having a hard time finding the answer to this question… I have a R32 GTS-T Sedan than has been 4 lug swapped using S13 hubs, rotors, and brakes. The front has also been converted to S13 suspension.    When the swap was completed, the handbrake cables were never hooked up, as the S13 rear calipers are the “handbrake”, and not the typical drum on rotor that the R chassis are. Does anyone know handbrake cables that will work for this conversion? I’d like to not use a hydraulic handbrake and stick with the traditional cable style. My original thoughts were to go with S14 cables and try to make them work, since I’m pretty sure S13 cables will be too short.    Any help would be appreciated!
    • I did some research, considering you have a neo engine, how is that battery compatible? I checked centuries website and super cheap and says it's not compatible. Only this full size one is. https://www.centurybatteries.com.au/products/ns60-mf
    • No, lets be honest here. I went to Winton and did a track day, for all the mods and V8 power and craziness I posted up a time that a K24 stock motor Honda Accord can do on the same tyres (narrower, too) 250kw and learning how to drive the f**kin thing is the sweet spot.
