Howdy,
Can i fit a r33 powersteering pump to my r32, and just block off the hicas oil supply and return lines?
Im getting a Tomei hicas lock for the car as well, so dont need to worry about the hicas. Id like to keep all the lines and rear rack in the car incase i want to have the hicas put back at a later date, so is it ok just to block off these oil lines?
My r32 powersteering pump is making noises (not its not run dry or needs bleeding) its more internal whirring bearings....so instead of getting this pump reco'd or a replacement pump, since im removing hicas i tought this might be a better way to go?
cheers :D
https://www.sau.com.au/forums/topic/49754-r33-powersteering-pump-in-a-r32/
Hi Bl4ck32, They are geared differently (check the pulley sizes), I guess because the R33 pump doesn't have to run the rear rack as well. Be carefull where you disconnect the rear rack plumbing as the power steering cooler runs of the return line from the rear rack solenoids.
Hope that helps
so i can just swap over the pulleys if they are different.
Nope not that simple, you really need to have a look at them side by side.
Where would be a good place to disconnect the rear rack plumbing then?
I removed the complete HICAS system from ours, it weighs heaps. Wait until you pick up one of the solenoids (there are 3 of them). After you have driven the car with no HICAS, you will never want to go back. As for the cooler I plumbed it in on the return line from the power steering rack to the reservoir. It's not under much pressure there. If you put it in before the rack it has to contain the full power steering pressure.
Hope that helps some more :D
Cheers SK.
Gotta figure out what i want to keep on the car then. The Tomei hicas lock uses the std rack, just with shims....easier to scrap the lot and use a lock bar i suppose?
How does this affect the computer? Ive got a PFC, so i dont know if the dash light will come on still. This was one of ther reasons i like the Tomei kit, due to the interceptor module....
Cheers SK.
We still have the R32 pump, I have been waiting for it to die but it just keeps on rattling. We use a billet alloy rear rack eliminator made by our race team fabricator. I pulled the globe, no HICAS warning light then. :D
Id just like to keep the rack and all lines there, incase i ever want it back on....ie sell the car or if im defected and need it on to pass inspection.
I suppose im gunna end up rebuilding the rb20 one then install the Tomei HICAS kit. I think that might be the easiest solution.....
you shouldnt need ever need it, if you do just put the rear rack back on with no lines too it for regeny, the 33 pump will bold streight up no probs, havent checked the pully sizes but hopefully i wont have a problem running with the rb20 harmonic balancer.
a complte new rear rack will only cost you $120 and be much more stable, i never had light in my car when i disconnected it all either
ever experienced the steering go stiff at slow speeds even with it disconnected?
My ps pump is stuffed. So keeping in mind i wanna diasble hicas later.....i can :
a) fix the rb20det ps pump on there now, then fit the Tomei lock kit
- or
B) remove the rb20det ps pump, strip hicas system, install r33 ps pump, and plug it up to use the ps cooler still, install a lock bar at rear
Im still running the rb20 harmonic balancer as well Clint.
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
