Any of you people tryed cryogenically treating engine parts whe building an engine? If you don't know what it is - nasa discovered it with the space shuttle in space - for some reason metals were coming back 300% stronger after a voyage. Apparently freezing metal to over -300degrees celcius does this! I read about it in a zoom article ages ago and just wondered is any angine builders use the treatment, as it is quite cheap - about 150 dollars to do a set of pistons.... I'd try it if using standard in say a rb30 with rb25 head
https://www.sau.com.au/forums/topic/49764-cryogenics/
  • Replies 56
Guest two.06l
yeah we use cyrogenics widely in our engines/cars dont tell too many people about it though its a secret ssshhhhhh!.More details about it can be read in the latest Autosalon mag which explains the process in detail.Paul....DIRTgarage.
https://www.sau.com.au/forums/topic/49764-cryogenics/#findComment-992101
Oh dear - absolute zero is at minus 273 Celcius. Perhaps everything in Zoom (or your recollection of it as above) isn't totally accurate?
There is plenty of information on the net about the use of cryogenics and the (perceived) benefits of strengthening engine parts.
https://www.sau.com.au/forums/topic/49764-cryogenics/#findComment-992105
Guest two.06l
mate unless you have proven nasa,nascar or even DIRTgarage wrong go back to bulgaria or disprove its worth.
https://www.sau.com.au/forums/topic/49764-cryogenics/#findComment-992113
Oh....this is good.
two.O6l - so what are you saying - nasa has redefined absolute zero?
You cannot get colder than this point, which I stated above is minus 273 Celcius. gtst25's statement of minus 300 is physically impossible, and therefore incorrect.
I also have a problem with the claim of 300% strength increase, particularly if this number is from the same source as the minus 300 Celcius.
Cryogenics can offer good advantages for cast and forged steels. The very cold temperatures do indeed offer a slight increase in hardness (not to be confused with strength), however the big advantage is in stress relief through a solid metal body that may have been introduced during the manufacturing process.
Personally, I think that it's not a bad idea and quite cheap insurance, particularly on cranks and blocks (i.e. large metal volumes). Forged pistons and rods, by the very nature of the manufacturing process, are already stress relieved, and therefore unlikely to benefit for the treatment to the same extent.
I am in Bulgaria as an expatriate Metallurgist from Australia. Whilst I am presently working on a copper concentrator/smelter, I have previously worked on a iron/steel smelter.
I think that I know what I'm talking about in this case.
https://www.sau.com.au/forums/topic/49764-cryogenics/#findComment-992177
Guest two.06l
Oh....this is good.
thanks for the quick lesson guru
https://www.sau.com.au/forums/topic/49764-cryogenics/#findComment-992183
Gav
being a Defence Engineer with a fetish for structural work and an interest in metallurgy I would be keen to hear your thoughts on just what may be the cause of the added strength. Would it be a secondary solid phase change due to the reduced energy levels of the atomic structure at those temperatures allow greater interstitial compaction, or is it a grain refining change like with HSLA steel? Just what composition steel is it ideal for? Low carbon? Will this be of any benefit to aluminium with silicon alloys as used in pistons? I'm a bit rusty at the moment on steel phases so a good discussion will do me the world of good and you seem the guy to lead the discussion. This isn't a come on. I'm serious and want your opinion.
https://www.sau.com.au/forums/topic/49764-cryogenics/#findComment-992184
Guest two.06l
I'm sure that gtst25 was using 'round' figures when he suggested 300 degrees? Surely everyone knows that a bath of liquid nitrogen is -273 degrees C. Isn't that common knowledge???
https://www.sau.com.au/forums/topic/49764-cryogenics/#findComment-992191
Not the sort of thing you would use round figures for, nor is a claim of 300% stronger. Stronger, harder, tougher etc are all pretty much known terminology, and everyone knows most steels lie at around 200-220GPa for Youngs Modulus and Tensile strength of around 300MPa Yield so how can you obtain such an increase?
https://www.sau.com.au/forums/topic/49764-cryogenics/#findComment-992212
Guest two.06l
sorry einstein
https://www.sau.com.au/forums/topic/49764-cryogenics/#findComment-992214
two.O6l
Actually nitrogen, it will be a solid at that temp.
I'm far from a guru, but this IS within (or very close to) my field of qualification and 16 years post graduate experience. I wouldn't belittle, nor presume to know better, your profession.
skylinegeoff
You sound like the one who can give a more definitive answer as to the benefits of cryotreating. I am familiar with heat treatment of steels (although my qualification is a primary metallurgist, and not a secondary metallurgist), particularly when correcting incorrectly quenched castings. The re-heating and controlled cooling allows for even crystal/grain formation and allows for internal stresses to be evenly distributed. As you will know, machining may be required after this treatment due to movement.
Now, cryotreatment, as I understand, is a bit of a black art with many claims made by the companies who perform the service. The trouble is that I haven't been able to find much published by independent parties as to the benefits. Again, I don't believe that strength is added, rather that internal stress sites are relieved, and thus restoring maximum (and uniform) strength.
If you have any references, I would be interested in finding out more. I am considering getting my freshly prepped block and brand spankers crank done.
Cheers
Gav
https://www.sau.com.au/forums/topic/49764-cryogenics/#findComment-992221
Sadly I was more concerned with getting to the CFRP's and such and studying high energy impact effects on RHA (rolled homogeneous armour). We tend to try to break things rather than make them, and the defence academy (a somewhat exclusive UNSW campus) tends to focus on things military. I see this as a hole in my skill set so I'll be just as keen to study any literature.
Perhaps I should set aside some time tomorrow for a search and I'll get back with waht I find.
https://www.sau.com.au/forums/topic/49764-cryogenics/#findComment-992236
two.O6l
skylinegeoff
Cheers
Gav
https://www.sau.com.au/forums/topic/49764-cryogenics/#findComment-992238
Guest two.06l
two.O6l
Just have a look at that statement, a contradiction of terms i must say. My field of expertise is owning, running and maintaining a sucessful race team. Doing all the work bar tuning of the cars myself and as this is a site dedicated to this subject, any help, not baseless statements would be of assistance. The science geeks are on another forum, if you want to bamboozle yourselves there then go ahead.Not here.
https://www.sau.com.au/forums/topic/49764-cryogenics/#findComment-992250
this isnt exactly my area/field but I thought this may add to the basic understanding for some
Quantum theory asserts that atoms and other elementary particles can be thought of as waves. Einstein proposed that as atoms approach absolute zero (-273.15°C), the waves expand in inverse proportion to their momentum until they fall into the same quantum state and finally overlap, essentially behaving like a single atom. The phenomenon (Bose-Einstein condensate) could not be observed, however, until techniques were developed to reduce temperatures to within 20 billionths of a degree above absolute zero.
In 1995 Eric A. Cornell and Carl E. Wieman led a team that isolated a rubidium Bose-Einstein condensate under laboratory conditions; two experiments by different teams involving molecules were successful in 2003.
It is believed that this state of matter could never have existed naturally anywhere in the universe, since the low temperatures required for its existence cannot be found, even in outer space. The condensate may be useful in the study of superconductivity (the ability of some materials to conduct electrical current without any resistance) and superfluidity (the ability of some materials to flow without resistance) and in refining measurements of time and distance.
https://www.sau.com.au/forums/topic/49764-cryogenics/#findComment-992268
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
