I am selling the following parts to make way for some upgrades.
RB20DET - complete engine, gearbox, and ECU, intercooler (stock). Major service done. 125000kms. Available very soon!
$2000
Standard R32 Wheels. Dunlop FM901 rear tyres and Falken fronts. Both have about 90-95% tread
$450
R32 GTST bonnet, navy blue in perfect condition - Heat liner is immaculate too.
$150
R32 GTST Type M front bar, navy blue in perfect condition.
$250
R32 GTST standard passenger seat - great condition
$30
R32 GTST rear seat - great condition - not faded.
$30
R32 GTST cat back exhaust (3 inch). Includes noise restrictor
$300
All prices are negotiable...
Email me for pics or call me for details. Will also check PMs when I get a chance.
Phone: 0412 591 369
Email: [email protected]
https://www.sau.com.au/forums/topic/49768-r32-parts/
oh ok...
just wondering...where can u get those r32 skyline floor mats? i aint talking about those u just buy off the autobarns and supercheap stores...im meaning the genuine nissan skyline fitted ones....i have been looking everywhere for them...
thanks
https://www.sau.com.au/forums/topic/49768-r32-parts/#findComment-993091
4 sale. 1x GREDDY manifold brand new to suit RB26tt
port nitrous injection, 125hp-800hp. 2x15 lb bottles fitted with
super high flow taps, purge valve, and tube bender.
all brand new still in packing all is complete, ready
to bolt on. this setup is psychotic. cost well over
$4500 sell the lot brand new 4 $2000
call kane 0415 116 174 will deliver if in sydney area
https://www.sau.com.au/forums/topic/49768-r32-parts/#findComment-1027205
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
