My shift light is spliced into the Apexi RSM from memory... red wire to power black to earth and the other one spliced into the revs output line from the apexi or the revs input to the apexi I'd have to check which
i have shift light hooked up to RSM aswell, hooked it up myself, white wire from RSM is used, that wire will provide an earth when a pre-set rpm level is reached, it is best to use a relay and hook up the white wire to one side of the coil on the relay and 12v to the other side of the relay, once that is done you should hear the relay click when the rpm level is reached (providing the RSM is setup correctly).
then it is just a matter of using a globe or an LED or a cluster of LED's and hooking it up through the switching contacts on the relay, if you plan on only using a single LED there would be no need for the relay (as the RSM will only allow 200mA of current), just hook the positive 12v supply up to the correct side of the LED and the negative of the LED to the white wire from the RSM and it will work (MAKE SURE YOU FIT A 560ohm RESISTOR ON THE POSITIVE OF THE LED IF USING A SINGLE LED!), i have made up a cluster of 7 high-intensity red LED's for mine, arranged in a circle, and damn its bright.
Hope that helps, and hope it just didnt confuse things...
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
