My friends white sII r33 was stolen from chaddy car park last week, was found but he has about 7 grand damage to the car. His stereo system is gone and a lot of damage done to the interior and the doors.
Those farkers at chaddy are obviously targeting skylines as this is not the first time a skyline has been stolen from there. Maybe we need to do a stakeout and find the little farkers and teach them a lesson.:D
Just a warning to those who park there.
https://www.sau.com.au/forums/topic/49774-chaddy-strikes-again/
Guest RedLineGTR
I personally think the trolley boys (try not to point fingers) from the car parks may have something to do with the increase of thief it may be a mates mate involvement, don’t know but it seems to have happened more often in the Coles car park than some of the others around Chadstone. Some of my mates in their skylines have had thief’s and break inns over the past 6 months.
anyone want to donate their car to the cause? :P
we'll get a crew together and wait til they try and brake into it... then smash their knee caps with baseball bats and tell them to pass it on haha
I think the Coles carpark gets more attention, because the all the bus stops are in between Coles and the carpark.
You always see deros waiting for buses and they get a front row seat watching all the cars come in. They probably don't even catch buses, but use it for window shopping and to look inconspicuous. Theres HEAPS better places to park than that crappy location. :dump:
why anyone would leave an obviously modded car in a car-park like that is beyond me.
further more, leaving it there without an adequate alarm system too.
fork out and get tracking for it. Mine will be once it actually drives :P
best security, and piece of mind money can buy
bah... the best security is this: replace your airbag with a 12 Gauge Shotgun and wire it to your alarm... if someone starts the car without the key then they will have a point blank problem... cleaning afterwards would be a bitch though.
Back on topic, i think the stakeout would be a good idea, just leave a highly modified line in the parking lot and wait. When the kunts show up we can get a dozen SAU members to totally freak them out and possibly break some legs :P ...
I've had my car for 2 years and it has only been at a shopping centre once and then I had someone waiting in it on guard
this was the exact thing that went thru my mind when i found out his car had been stolen!! I guess my young friend will learn the hard way. He had been spending money on mods while the car security was ignored.
yeah i have worked at chaddy for the last year or so, see quite a few skylines parked there on a regular basis...thou i don't park at the coles entrance. On another note about 8 people from my work have had thier cars keyed within the last few months which goes to show the security at chaddy needs improving, ie cameras on all the car parks.
i'm up for the stake out!!!!! :uzi: :boinkcar:
Send me a PM when you guys are going to doing this; I got a whole group of angry skyline owners that will come down to pound the crap outta these mugs.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
