Nice conection there, but its on xbox. There needs to be a pc version, its not out yet, suprnova does have torents for the ellusive pc version is not there, in conclusion.... dam you funkymonkey
EDITED: Skyzer
anyone that wants any info on getting this game like the monkey which is funky here are the links to places to accually DOWNLOAD THE GAME
bit torrent client (needed for download you dummy)
www.shareaza.com
Bit torrent site.
Once you have shareaza installed simple go to the following site, there all good as gravy
www.suprnova.org
www.torrenreactor.net
www.bitgoogle.com (might not work)
and then find the game, and using shareaza anti martin technology(it means its good)
it then loads the torren (dat file) and it downloads !!, the downloads start of slow as they should, then they go pretty fast pending on how many sources there are, if its a new game that everyone wants then you will get it in no time.
in conclusion.... there is no conlcusion.
https://www.sau.com.au/forums/topic/49818-juiced/#findComment-993386
Accliam are going out of business.
That means the game that I was waiting for for sooo long may no be released.
They are sacking all their employees and the Offical PS2 version may not come out.
That's sh1thouse.
https://www.sau.com.au/forums/topic/49818-juiced/#findComment-1027148
    • Yeah. I believe the fear of annealing the alloy and weakening it, Every online discussion has someone saying it's bad and potentially a risk when powder coating forged wheels.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
