Guest tgriffin
Driving an R33 GTS-T *normally* in the dry (I mean taking corners at equal to or less than the speed limit), is it common to lose the back? Or only in the wet?
Originally posted by Risto
majt buy a gts-t u wont regret it. i had no idea how to drive a manual  4 weeks ago  and i bought my gtst u learn quick trust me after u crunch the gears 100 times and release its costing u money ehehe u learn very fast + they nice and smooth  unlike some old et turbo ehehehe would shake rattle and role :) when u drive. just watch out its scary the first couple of times when u experience the boost kicking in, and as they have already told u watch out on the wet they slide out nicly,  but also they have great handling unlike VL's which would in most casses be uncontrolable when doing a stand still :P ud usually  loose into poll but id recomend u dont try doing one for a few months yet ehehe :mad:
  • Replies 59
I drive a R33 GTST on my p's never been hassled about it even though i have been pulled over before.
Power to weight is a very grey area with cops. The most common way for them to check is by reading the VICRoads Restriced vehicle list of which the skyline is NOT on!!! Gotta love imports :)
Plus the road weight of a R33 is ****ing heavy so its really close to legal mark anyway...
no the handling is mad well i havent driven many cars but ive driven bout 7-8 different type includin xr8 and vl turbo i would say they r the best at handling thats why they are made for drifting very nice
also about been hassled buy cops u shouldnt have problem friday night i was driving down chapz unfortunatly i happend to stop infront of kfc due to traffic copper right next to me he just shined his torch inside of car to check for neons and guages then turned around if u dont drive dumb :) or have neons or guages like monsters on ur dashboard u should have no problem with cops
in no particular order
I personally am a confident driver
being a confident driver and a good driver are 2 different things especially someone who hasnt got their p's yet.... speaks for itself
really? What mods are these
if you place a sheet of metal with 19 10mm holes drilled into it and place it on the panel filter it will reduce the power to approx 133kw at the wheels a legal limit in a skyline for a p plater
Now i was wondering when i was talking with my friend about this issue. The factory r33 gts-t runs at 8psi so if i bring down the boost to 6 or 7 pis would that bring the kws?
dont touch the boost do the plate thing....8psi?
it is very possible to drive a skyline in any condition and not be worried about losing it this comes with driving experience in your car...however once you get this experience you are more likely to want to make the back pop out in the wet....
There is no such thing as a restricted vehicle list any more... this is the old method it purely goes on power to weight these days
if u dont drive dumb  or have neons or guages like monsters on ur dashboard u should have no problem with cops
Agreed!
I agree totally.........
There's a big difference between confidence and competence.
(Just ask boxhead) :)
There is a restricted vehicles list, and it is available from vicroads
From their site:
While you can drive most vehicles, you are not permitted to drive a high powered car. These are cars which have a power to weight ratio greater than 125 kilowatts per tonne or with a capacity to weight ratio of more than 3.5 litres per tonne. A list of cars which may not be driven is available from VicRoads Registration and Licensing offices.
P Plater restrictions
ok i currently stand corrected however when I was looking into this restricted vehicle list(4 months ago) i did read somewhere that the rule had infact changed and it purely went on the power to weight ratio....but it says on their site that it is still valid so I guess I am wrong...unless they havent updated their site?
Originally posted by chopobo
Now i was wondering when i was talking with my friend about this issue. The factory r33 gts-t runs at 8psi so if i bring down the boost to 6 or 7 pis would that bring the kws? and would vicroads accept this type of downtuning?
Technically, if you reduce the boost the car will be P plate legal. This is fine according to vicroads... if you can prove it. You'd need to ring 13 11 71 and ask for the Road Safety dept. They will prolly tell you you'll need an engineers certificate (for the mods), then prolly a dyno reading at the engine, and a roadworthy. After all that they'll put a notation on the system so whenever you're pulled up, the coppers can check the mods and make sure they're still in place. If they're not big fine then canary. Give em a call to confirm.
Here's how its worked out:
A high powered vehicle is any vehicle with a power to weight ratio over 125 kW per tonne, or with a capacity to weight Ratio over 3.5 litres per tonne.
The weight of a stock standard vehicle is measured in tonnes (1000 kg = 1 tonne) capacity is measured in litres (1000ml = 1 litre), and power is measured in kilowatts (kW).
The power to weight ratio (kW divide by Tonnes) must be 125kW or under.
The capacity to weight ratio (Liters/Tonnes) must be 3.5 litres or under.
It is still available, but its a bit useless. That list hasnt been updated since 1998 so the web page is a little misleading. The restriction now applies to any vehicle with more than 125kw per tonne (not just the ones on that list).
you can modify the car so it wont be as powerful yes.....modify it so it is legal to drive and then get insurance for it as a modified gtst. that can be done easily
does anyone know someone who has done this? I've tried to find out information about modification to lower the kw output and the insurance/legality around this but no-one seems to know much :D I'd be interested in hearing from anyone that has found out if this is viable
Thanks,
Paul
Thanks,
Paul
mate the insurance company isnt going to care how much power u have at the wheels.. for the pure fact that there are only a couple of companies that will insure u if ur under 25.
all they care about is the type of car, ur age, what mods u done to it etc...
if u wanna insure it ur better off getting a stock one to get the low premium and do it up as u go along and tell them the mods ur doing which will go towards the premium next year which will obviously be less as they go down each year (providing u havent claimed in that year)
..get insurance, pay the preimum, then if a claim was made there not going to use the info provided to use a legal vic roads clause to get out of paying the claim? I'm sure it would be in the contract that all road rules have to be followed etc
im uninsured at the moment with my line... til i get rating 2 next year.
crazy mate, ur the first guy on this forum who i've heard that that they're not insured, i'm with you!!! i'm also uninsured :D at the time that i bought my car i didn't have enough funds to pay$2500 to just cars. then if something does happen u have to pay them the excess and then under age excess and import vehicle excess and crap so i decided it wasn't worth it. i really should hop onto 3rd party but i'm planning on selling soon so thats not worth it now either.
does anyone know someone who has done this? I've tried to find out information about modification to lower the kw output and the insurance/legality around this but no-one seems to know much  I'd be interested in hearing from anyone that has found out if this is viable
i did this to get insurance... with just cars as they wouldnt insure me as i wasnt off my p plates...
the insurance company cared in my case!
i know a 20yo who had a 260kw 300zx and crashed it... was his fault but he wasnt speeding or anything in which case they fulfilled the claim... took a while but they did it.
This is all good and well... most probably the insurance company will pay up if you are driving a car which is deemed too powerful however what happens if they look further into it and refuse eh??? there is no guarantee that they will pay!
    • This is lower price now given apparently nobody wants these or needs them. It's 550 but if someone sees it on SAU and wants to make an offer, please do so.
    • LS is a good motor, but it hurts my soul when I see it in a RB. Guess it fixes the oiling issues lol.
    • I'm confused. Does this qualify as "Gregging" or are you somehow avoiding the Gregging?
    • More assembly going on, with all sorts of "bolt right on bro" scenarios going on here. Smartly, PTV clearance was checked. And I say smartly because it turns out that the intake was 0.009" from piston meeting valve. This is 0.23mm. This is very not okay. A fast meeting was facilitated between engine builder in Australia and engine builder in the USA which was actually incredibly helpful and constructive actually, various ideas thrown around to get around this issue including: 1) Retard the cam timing which would have brought the exhaust valve closer to meeting piston (it was 0.065") which was uncomfortably close to begin with, and change the cam profile making it 'laggier' 2) Much larger head gaskets which would reduce compression, but half the point of this was to increase compression. 3) New set of pistons ($$$$$$$$$$$$$$$$$) 4) All of the above 5) Get ghetto The concept is you get sticky sandpaper and stick it back to a valve, slightly larger than the valve you/I'm using, like say from a LS3/rectangle port head. You now have a very super advanced flycutting tool to modify your pistons in your block. Then you install it in your head, and attach the other end of the head to a drill. Then you just replicate your valve smashing into a piston with your spinning drill.   This is the result. Repeat many times. It is strongly recommended you have some kind of fixed stop when doing this for extremely obvious reasons because if you press too hard then you're well into apocalyptic repercussion land. The minimum clearance on the intake valve is now 0.075" this is still in the "Too close to be really comfortable" and into "It should be fine" land. Supposedly in the real world the clearances will be slightly bigger. Guess this is what happens when people push envelopes for N/A engines instead of adding boost! Time to move onto the new, upgraded, higher ratio roller rockers from Yellaterra, all tapped and threaded with a stronger bolt for better stability. Very nice. Lets see how they fit. For f**ks sake. Time to bring the grinder out for these aftermarket, machined and CNC'd heads. Looks like the new, beefier rocker from YellaTerra has gone from Bolt on part to "Bolt on part". Well, lets see how this bolt on crank scraper and windage tray goes then, shall we? There actually is more clearance than they specify for this thing, but seeing it all move as you check it is terrifying when you see it all so very very very very nearly hit things. But after all, this is what the item is designed to do after all and actually did bolt on perfectly and have enough clearance to everything and some very clear and direct instructions. So +1 to Improved Racing I suppose. As above with the windage tray on. Photo of breaker bar wonkiness for added lols. Next up: Oil pump/front cover/water pump/sump and then it's time to actually install the heads, pushrods, head bolts, valve cover gaskets and such is all there and ready to go. (except the oil pump bolts which were previously longer for more clearance with the previously perfectly installed double row timing chain). There's definitely a sense that someone other than us has been here before and done everything perfectly, or at least considered it and came up with working solutions. Perhaps the previous cam was 6deg advanced to avoid PTV issues with the milled stock heads? In any case when I attempt to sell this stuff the buyers are going to be very directly informed.
    • my catch can is pretty easy to empty but it overflows due to the blowby/crank case pressure etc. max I have drained is ~600ml even with a ~2.3L capacity. So it is not just about having to drain it out its the mess it makes down the firewall and under the car and rear passenger tyre from the overflow oil being blasted by screamer + air in general. Ending up on the ground cleaning the oil up and having oil on your arms when everyone else can chill and watch the other sessions gets old fast
