DRIFTT,
My car is NOT auto. I know Apexi don't make ECU's for anything Auto. That is not the problem, Apexi don't seem to make a ECU for a MANUAL RB 25DET which is also 4wd like the Stagea.
Gtst25, Good price on pfc, but unfortunately that won't work because of the four wheel drive system onj the Stagea
Cheers
Gary
https://www.sau.com.au/forums/topic/49838-power-fc/#findComment-996604
DRIFTT,
Cheers
Gary
i saw a modified stagea on jap site..(can`t find again)...but he was using HALTEC ems
may help
https://www.sau.com.au/forums/topic/49838-power-fc/#findComment-996643
DRIFTT,
Cheers
Gary
Hi Gary, I see no killer reason a GTR Power FC wouldn't work on the RB25DET manual Stagea. You would have to parrallel up the feeds to the AFM (RB26DETT has 2 and RB25DET has 1), its only 1 wire. Plus you would loose the VVT of course (RB26DETT doesn't have VVT) but that gives you the freedom to use GTR (non VVT) cams, so no loss really.
The Emanage would be an "easier" solution but you would loose some of the PFC tunability. I guess it really depends on your power target and the involved mods. Personally up to ~220 awkw I would use the Emanage, over that and its Power FC time.
You should also have a talk to Steve-SST he can probably give you some tips on using a Wolf.
Hope that helps :D
https://www.sau.com.au/forums/topic/49838-power-fc/#findComment-996693
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
