I Just wanted to get other peoples view on this
I'm currently looking to buy a R33 GTST -1997 - Manual - 12 months rego Mspec
full stock , mint condition for $24,000.00 is this a fair price?
Will be the 1st driver in australia just imported.
Is there any point in doing a rev check when its only been in australia for 1 week.
will be the 1st australian driver?
If the car has only just been imported, it has obviously never been registered in Australia before so it will not have had any finance on it.
REV's checks for encumberance on a vehicle, ie money owing, so this wont be nessesary on a freshly imported car
I bught mine the same way you did.
Someone imported it and i bought, so second owner in Aus but 1st registered on road owner.
The don't bother with REVS comments.....just do it man!
I did even though it was just in. It doesn't hurt and takes you a whole 5 mins of your life!
...and its free.
get the vin nuimber checked... nissan at hornsby will look it up for you... this will show if it is the car that left the factory with the vin that is on it now, colour etc..
also get someone who knows these cars to check it out for you, lots of things can be wrong with them!
iissavi: The guy you need to speak to whos clued up on imports at Hornsby nissan is away.
Also an NRMA inspection is a waste of your money, they will happily tell you that your wiper blades are ok and your tyres are fine but they arent trained in performance import vehicles so you are best to either arrange to get the car inspected at a performance shop or get someone you trust and who really knows his stuff to go over the car with a fine tooth comb. Either way make sure you do a compression test.
Where is the place you are buying the car from?
iissavi: Tell the dealer/seller that a condition of your purchase is that they allow the car to be taken to a reputable import performance workshop for a thorough checkover prior to laying down any funds.
I sold my GTS-T a few years ago and Jim at CRD in Silverwater inspected my car for the new buyer and I was incredibly impressed with the level of detail they went to.
They checked the engine, body, every switch inside the car, radio, road test, braking, suspension etc etc and dynoed the car to ensure everything was in good working order.
Expect to pay around $200 for a full inspection, and believe me, its money well spent.
I normally speak to John in parts at Nissan
You may be able to try the parts division at Crows Nest Nissan as well
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
