I own a 1977 Datsun 240k GL 4-door. Unfortunately it's the automatic version but at $150 for an otherways perfect(aside from a few dents and blocked fuel filter) car I'm not complaining too much.
My plans are to fit a late model turbo engine(undecided at the moment, but probably an RB20DET) and build a nice looking(to me at least), old-school driveable car. I want to get the body 100% before I start work on the engine and driveline but I can't find any pictures of my car for inspiration.
After spending hours browsing japanese sites and only finding grainy pictures of 2-doors I'm turning to you. Please post some pics of nice looking four foor c110 and c111 skylines. :P
https://www.sau.com.au/forums/topic/49867-240kc110-4-door/
plenty on here, only problem is it constantly hits it's bandwidth allocation.. but hey, that is probably because our car is on there :P
http://sgt77.topcities.com/
and the GTR :Phttp://www.enthuno-mori.at-server.com/niss...20040208nissan/
also there is a forum on www.classiczcars.com for 240k's but i think we are slowly converting them to SAU :(
congrats on the purchase, great price!! keep an eye on our website as alot of your conversion would follow ours :D
https://www.sau.com.au/forums/topic/49867-240kc110-4-door/#findComment-993634
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
