Here is information about the Type 0 and Type 1 and difference between the two.
TYPE-O has the following functions.
TIMER MODE-This mode keeps engine still running at idle speed after turning the key to off position, and cools down the engine and the turbo by circulating engine oil. This timer has manual, memory and auto mode. Manual mode enables you to set the after-idling time as you like in the range from 0 to 10 minutes (every 30 seconds). Memory mode is the one that several after-idling time is already set in the factory, and you can choose from one of those after-idling times. In the auto mode, turbo timer sets the after-idling length automatically by calculating it from engine running condition.
BATTERY MODE-This is the mode to show the battery voltage in its monitor. If you want, you can set battery warning, which warns you by warning sound and changing the monitor colour when the battery voltage becomes more than 16V or less than 10V.
TYPE-1 has the following functions in addition to two functions which TYPE-O has.
SPEED MODE-This mode shows you driving speed (in the range from 0 to 399 km/h) and also you can set the speed that warning sound will inform you if you drive over that speed.
ENGINE REV MODE- This mode shows you engine rpm and peak rpm. By setting warning function, you can also use this mode for gear-shift timing or red zone indicator.
STOP WATCH AND LAP TIME MODE-
In this mode, you can use this turbo timer as stop watch.
0-400 TIME MODE
In this mode, you can measure the time of 0-400m by using count-down start or auto start that sensed by car speed.
https://www.sau.com.au/forums/topic/499-hks-turbo-timer/#findComment-12830
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
    • I've been quietly following this thread for ages, but this one got me. Since my ADHD diagnosis (and associated learnings and prescription) I'm way less inclined to wade into forum yarns when there are better things to do with my time, as half the time I'd end up in some kind of forum debate even if that wasn't my intention. I've not lost the ADHD "superpowers", just am a lot better at directing my hyperfocus into slightly more constructive things, but haven't stopped quietly lurking in here in my spare time.
    • Stripped the tank down and gave it a good scrub. It came up really good! Not sure if I'll just put it back in like that or give it a blackening treatment (such as Bowdens The Black Box). That might give it a matte look so might just run it as is.
    • @MBS206 Ha ha, yeah ADHD is a daily battle to not get drawn in to doing things you want to do that you know you shouldn't do!  Every single time I walk into my shed I end up doing something I started the day having zero intention of doing! I keep mentioning the 1 step forward, 3 steps back scenario and I'm tipping people that are blessed with ADHD (yes, blessed) are the worst at that!
    • We import a lot of cars from Japan. I'd say that approximately 20% of our traffic is imported JDM cars (mainly consumer cars like the Mazda Demio, Toyota Yaris, Honda Fit, Suzuki Swift, etc.). We also import a lot from the UK, but this has decreased after Brexit. Apart from the consumer vehicles, two of the larger, well-known dealerships frequently import iconic '80s/'90s JDM cars. I haven't heard of anyone importing from Australia, and they are not advertised (unlike Japanese ones), despite a lot of Maltese migrating to Australia in the '50s and '60s.
