240z-RB20DET
Just a question. You removed the notch and turned the squirters so they don't hit the piston. All well there. Isn't the notch there to make sure the hole in the banjo bolt and the oil feed hole in the squirter align? Doesn't turning the squirter mean these two won't align now and there will be no oil flow through the squirter?
The availability of e85 won't matter with a flex tune. Can mix and match and never have range anxiety again. Only thing will change is your ethanol %.
Jamie does know his stuff , you might just want to give them a call and ask - here is their FB page - https://www.facebook.com/profile.php/?id=100063506985512 - you will find the number to call them on.
Do you think the guys in Penrith are install the E85 Kit?
