Gday,
Just wondering if in NSW you are required to have a muffler?
My import will most likely have a straight through. I will be putting a high flow cat on it but if I don't need a muffler I won't get one.
Assuming it's not loud enough to attract attention, and other than noise pollution requirements, is there any legal thing about not having a muffler? EPA or other?
Thanks.
https://www.sau.com.au/forums/topic/49938-illegal-muffler/
That's true.
Thing is I know someone with a straight through and it wasn't that loud.
My 351 straight through wasn't loud either.
I'm just worried about the environment and I can take care of my ears.. things is it's not that loud.
Anyway - in the end I'd like my car to be totally legal and engineered thats why i asked.. i was kinda hoping not to have a muffler.. I just didn't realise you need resonator as well.. this is getting expensive.
Back to hunting for that kakimoto straight thru!!!!
https://www.sau.com.au/forums/topic/49938-illegal-muffler/#findComment-994430
go nuts man. its only illegal if u get caught.. dont drive like a shit to attract the attention and u'll be fine.
friend of mine has lasted a week so far with a apexi super cat into a twin 3inch system straight out the back .. its loud as hell.
and i run a hi flow 3inch cat and one redback muffler.. cops dont even look at me twice
https://www.sau.com.au/forums/topic/49938-illegal-muffler/#findComment-994446
ive had a blitz nur, and even with a 2.5inch cat and the silincer in it, it still registered at 100dB. after 5 minutes of driving with no silincer, i would always get a bad head ache.
like cerial killer said, theres no point doing something so blatently illegal for a small gain. just install a good brand exhaust and be done with it.
https://www.sau.com.au/forums/topic/49938-illegal-muffler/#findComment-994600
Ive got some jap exhaust with custom piping wth no resonator. It really sucks. Since im driving in sydney, 90% of the time im stuck in traffic, or at slow speeds which = cabin drone!
Its louder than my friends s15 with Apexi N1 exhaust...
Im getting a middle muffler (resonator?) put in this week
but its wierd, after 3500rpm, the exhaust loses its drone and sounds pretty good
https://www.sau.com.au/forums/topic/49938-illegal-muffler/#findComment-995300
yeah i hear ya.. i hate that low rpm drone.
Funny thing is i have a mate with rb20 straight through .. sounds sweet - quiet as and sounds deep and quiet at low rev, gurgly thick mid and with that little bit of RB raspiness in high.. really nice...
I also have a mate with a rb20 with kakimoto cat back (don't know about the front pipe) with cat, resonator and muffler it sounds just as good if not better.. has that nice touch of kakimoto muffler (love that sound)....
who knows!
I hope kaki's flow well - that's what ima have to pick up methinks.
https://www.sau.com.au/forums/topic/49938-illegal-muffler/#findComment-995391
my exhaust is 3" from turbo back. Hi-flow cat, the cat back has no resonator. It's not overly loud idling but become really droney between 2K-3Krpm which is where you do majority of your driving (if it's a street car). Very annoying. The EPA test is done at about 4,500rpm from there it's not that loud - I think about the same as the engine. What exhaust do you currently run?
https://www.sau.com.au/forums/topic/49938-illegal-muffler/#findComment-995444
Cereal - currently my exhaust is about 2cm thick going to a 2.1cm oval shaped tip. It's made by opel sports.. err i mean the barina is sick.
The car I asked was the one on the boat which is straight through. -=> I don't wanna kill trees and kill our planet.. I take long enough showers as is so I wanted to know what the dillyo.
Guess I'm gonna have to call justjap every 2 weeks till a kakimoto cat back comes up.
Suggest any other places likely to have one? :cheers:
https://www.sau.com.au/forums/topic/49938-illegal-muffler/#findComment-995850
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
