what parts are needed to put an RB26DETT 4 wheel drive in to a R33 GTS-T apart from engine,gearbox,loom,ecu, i guess what i am trying to say is what little fiddlie bits do i need like may be engine mounts or suspension parts to make it front wheel drive need some help guys !!!!
https://www.sau.com.au/forums/topic/49975-rb-heart-transplant/
Guest two.06l
Different floor pan would be a start. Not the easiest of conversoins to do but definately doable. My advice sell the r33 gts-t and buy the real thing would roughly work out the same price minus the headaches, and the added value of having the real thing.
transfer case wont fit among other things
so you basically have to do a cut and shut on the front end like the way YLWGTR repaired his car.
big job might as well buy a GTR unless you get all the parts for free and do the work your self.
lol @ NZ forums, the place where bullshitters unite
RWD would be the easiest option modify the sump and your ready to go.
still tossing up what we are going to do with my car but the RWD is looking like most likely option.
Peter at Advan Performance has a thing called Gracer that started out as a GTST I think unless there was a GTS4 33, which I don't think there was. It has a worked to the sh*thouse RB26.
Hey mate, don't appreciate that.
We started the online skyline thing probably before most of you even knew what a Skyline looked like.
The internet is full of bullshitters, I don't see how NZ forums are any worse.. :bs!:
Coming from someone who drives a pink GTS.. i take it with a grain of salt..
buddy i have not got one peice of valuble information form SDU.
all i found out was that green nugget had over 100K spent on it which is complete and utter bullshit.
btw my car isnt pink its being painted candy apple wild cherry and i have built an RB26 which is going in within the month that is going to make some nice numbers.
its a full blown show car.
so sit back and enjoy the show bud.
now now children i am 27 years old and remember a red r32 skyline gtr ziping it's way around a track in oz by some fellas by the name of skafe and richards or was that another australia any way this isnt on the topic and i could go on this for hours
so the conclusion is rb26dett rwd in the gts-t would be the best or would it ??????????????
what about rb30 conversion or just to much stuff around
Well I have got a lot of useful information from SDU from the past 5 or so Years I have been there.
Don't know what you mean by green nugget?.. unless you mean the Green GTS-T which most definetly has had $100k spent on it. Which is very easy to do when building a show car... you will find out when you run out of money the first month in. :D
And without that site I doubt this one would have started or be as good as it now is.
And comparing the Bathhurst GTR's to one you may see on the street or own... a little different..
Anyway... sorry xr8eater.
Yes an RB26 in a R33 would be nice.. RB30 is good too. Depends what you want.
But as you first asked.. no not worth making a Rwd R33 GTS-25T into a 4WD GTR.. start with a 4WD chassis if your doing that.
I have done several quotes for people for doing this to a GTS4 and it simply is cheaper to sell the GTS4 and buy a GTR. As for doing it in a GTST, the floor pan changes would add a few thousand to the cost of doing the GTS4.
My suggestion, as always, sell the GTST and buy a GTR it is cheaper and you will have a real GTR, not a GTR copy. So you will get more for it when you sell it. :rofl:
Don't know what you mean by green nugget?.. unless you mean the Green GTS-T which most definetly has had $100k spent on it. Which is very easy to do when building a show car... you will find out when you run out of money the first month in. :rofl:
i have outlined how much that car wuold have cost to build on SDU. some of the figuers are simply bullshit. every person i have told about the prices he said laughed at him.
my car is nearly finished and its been in the build for well over 6 months money isnt going to run out because everything if basically paid for.
back on topic - if you really want an RB26 get the sump modified and run it RWD its not very difficult at all. or if you wantn to build a fresh engine build an RB30. the only limiting factor is money. work out your budget and build what you can while having some extra funds for those unexpected things that alway seem to go wrong.
thanks heaps guys i have looked at the rb30 conversion thread and have decided to put the rb26dett in simply because its to much stuff around finding and altering far to many parts wich leads me to these questions is the rb26dett a strait fit to the gear boxes in a gts-t what about the wireing to the speedo and revs from the rb26dett ecu and what about the engine mounts arnt they diffrent is there some adapters for this application.
lots of questions i know but im sure you guys can make me think of lots more with your replys
2GU UP 2, maybe the price for that car dosn't add up.. i agree. But maybe he got ripped off? :rofl:
I know if I didn't do all my own work and get good deals.. my car would have cost me a hell of a lot. And it's not even show standard, or finished.
Xr8 eater. The Gearbox will bolt right up. Best to use a Rb25DET box however.
Speedo can be modded any way that is needed so thats not a problem.
Revs is fine. This is only a problem when changing engines with a different amount of cylinders. Eg, 4cyl to 6.. still not a big problem.
Engine mounts are the same.
XR8eater;
I agree with Sydneykid and GTR Ben said; respectively I'd suggest they are right on the money. And if you are up for it by all means tackle the RB35/26/30 conversion; however, make sure you understand what it will/won't give you. It all gets down to the usual question of 'what do you want to do with it'.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
