thanks heaps guys i have looked at the rb30 conversion thread and have decided to put the rb26dett in simply because its to much stuff around finding and altering far to many parts wich leads me to these questions is the rb26dett a strait fit to the gear boxes in a gts-t what about the wireing to the speedo and revs from the rb26dett ecu and what about the engine mounts arnt they diffrent is there some adapters for this application.
lots of questions i know but im sure you guys can make me think of lots more with your replys
XR8eater;
I agree with what Sydneykid and GTR Ben said; I'd suggest they are right on the money. And if you are up for it by all means tackle the RB35/26/30 conversion; however, make sure you understand what it will/won't give you. It all gets down to the usual question of 'what do you want to do with it'.
XR8eater;
I agree with what Sydneykid and GTR Ben said; I'd suggest they are right on the money. And if you are up for it by all means tackle the RB25/26/30 conversion, it's been done successfully before and if you can do the research and harness some experience go for it; however, make sure you understand what it will/won't give you. It all gets down to the usual question of 'what do you want to do with it'.
There is a good thread on here re GTR vs GTST 'which is faster for the money you spend on mods' but I think it primarily discusses R32s. Nevertheless it's thought provoking and worth a read. If I'm not mistaken, Sydneykid uses an RB31 DET in an R32 GTST as his weapon of choice on the track. I think that tells us something. '
Just my 2c worth.
got ripped hard by the looks of it anyway at least we agree on that.
4 to 6 cyl? i thought this was all about an R33 GTSt???
if thats the case its should be a straight swap get ur self a half cut and swap away :P
I was saying he didn't need to worry.. I had to change the tacho in my car as I went from 4 to 6 :(
XR8Eater. The RB26 is an animal ;)
Best to do the turbos to a non ceramic at the same time though..
Guest MFX_R33
I have heard you also need to fit an RB25 sump to the RB26 so it will fit.
Depending on how much you can get the RB26 for, as they still tend to be very expensive and some of them for sale are getting very tired (15 years of thrashing). You may well be better off spending the same money on the RB25.
Jeff.
i have an rb25det sump can i use the pickup out of the rb26dett for this mod
and to mfx-r33 it would be a fifteen year old engine but i would install new rings,head gasket bearings if stuffed and take a good look at the turbos or exchange them for refurbed ones
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
