Question:
Hicas, when dose it work, how does it work, why does it work...
This is for me and other who would like to know...
Is all wheel steer as i know, and it works at certain speeds for handling..
Is this correct..
What speed?
Can you feel it?
I have a R32 Gtst and its got hicas... im sure it works, i swear i can feel it...
But i put it up on a hoist, put it in gear hit like all speeds turned the wheel and no rear wheel action...
Whats goin on?
Any help would be appreciated:D
https://www.sau.com.au/forums/topic/50006-hicas-issues/
Question:
Is this correct..
What speed?
Can you feel it?
Whats goin on?
You won't get it to work while the car is stationary unless you put it into diagnostic mode which is not straightforward.
It deflects the rear wheels differently above and below 60 km/h as less defelction is required at higher speeds.
In a nutshell the idea is to try and induce understeer for safety and for 90% of people it is probably a good idea to keep it connected.
There is a long thread on HICAS on either the handling or forced induction forum. Try an advanced search for HICAS with threads/posts by Sydneykid and you'll get the whole enchilada explanation.
Regards
https://www.sau.com.au/forums/topic/50006-hicas-issues/#findComment-995399
Question:
Is this correct..
What speed?
Can you feel it?
Whats goin on?
In a nutshell the idea is to try and induce understeer for safety and for 90% of people it is probably a good idea to keep it connected. What can make the car go mental is the fact that it is controlled by an old tech, slow ecu and if you are balancing oversteer on the throttle it suddeny goes 'oh I know, I'll help now by inducing understeer' with the result that it will turn the rears and reduce the friction level of the contact patch even further, possibly causing a lose. This is the time you go 'stop helping, you sh$t box'.
Regards
https://www.sau.com.au/forums/topic/50006-hicas-issues/#findComment-995403
oh oh oh... yes i get you derrr.
Sorry
Try the DIY forum or the susp forum, there's a tutorial there. Good luck, there's also a lot of cases of people having a rant because the diagnostic mode procedure is so mental. It's funny seeing the car sit there and twitch it's back wheels from side to side.
https://www.sau.com.au/forums/topic/50006-hicas-issues/#findComment-996145
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
    • Nissan needs to forget about building SUVs in every size possible and bring back the damn Silvia/200sx duo to compete with the 86/brz. Maybe with the Honda type r motor pointing the right way
    • Good to see you followed your heart, got your dream car and have it pretty well sorted out now. I think anyone can get caught out with a seller not being 100% honest about a cars problems. Can relate to all the electrical issues, had similar issues with my first car (mk2 escort) ages ago
    • I just bought the Nexus S3 for my gtt, haven’t installed it yet as I’m collecting parts to do everything at once…so far spent $14,000 The Nexus is nearly future proof
